11.0a port cockpit locker lid
Jan 25, 2011
2,437
S2 11.0A Anacortes, WA
This lid has a piece of wood across the bottom as a stiffener. Mine has been missing since I bought it. Can someone measure theirs for me? Specifically, the thickness as the prior print is still there. Also, what wood was used? I need to get this stiffened up. Was thinking of using a piece of oak.....
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
i replaced mine ...it was 3/8 thick ....i glassed it in with thickened epoxy resin....i used marine grade plywood and rounded the edges...and painted it with water based epoxy to match the hull liner color
Sep 6, 2011
435
I'm not sure I have such a thing. Is the wood on the horizontal or vertical part of the lid. I'll look closer tomorrow when it stops pouring.
SC
Jan 25, 2011
2,437
It's on the vertical part behind the lock hasp. It keeps the lid from flexing and over closing...
Sep 6, 2011
435
Ok if I have it I will measure it for you tomorrow. It is raining to beat the band here this evening.
SC
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
Is it working well? I was thinking of just 5200 it in with some clamps
works great it is they way s2 did it when they made the boat mine is on the inside of the lid flange...the original one was rotted out on the lower edge from trapped water so i removed it and replaced it...i did clap it in place with the lid in the open position..i also used waxed paper on the exposed area between the clamps and the wood to keep down the mess till it set
Jtoben
Jan 14, 2011
93
S2 11.0a Holland, MI
We replaced ours exactly as the woodster did. Several years ago, still perfect. His dimensions are right on.
