Check your bracket
The link to the motor discussion for the 22 is interesting, but the 23 is a significantly heavier boat.I just replaced the outboard on my 23. Based on searches and discussions, I found owners using 6hp to 15 hp (the max. that the boat is rated for per the original brochure). The key is what currents you encounter. I had an 8hp, and moved up to a 9.9hp; performs much better for me when returning to harbor against the outgoing tide. So I agree with your size choice.Four stroke has fuel and environmental advantages, but you have to have a bracket that will handle the weight and torque. I found that the bracket manufacturers are specific on wieght, hp, and 2 or 4 stroke, so you need to check yours. I stayed with a 2 stroke Mercury. My bracket position works well with 20" shaft. Current model is very quiet, and weight is 73 lbs. Good luck.
