I had one....
on an older hunter 30...Pros - relatively simple ingine, ran forever, couldn't kill it, probably used a quart of fuel an hour at full throttle, reliable - always started. Supposed to be able to hand crank start if batteries failed. I was never able to(for fun) batteries never failed so it always turned over.Cons - single cyl made it vibrate more than 2-3 cyls, actually broke a motor mount once, noisy- although you could probably try to add soundproofing materials to engine compartment. On the 30' it was OK when wind died and barely acceptable to motor against wind, chop, current. The 27' is probably 2000-3000 lbs. less displacement.
