07 H-36 windlass
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
I would like to take the top caption off to add grease which been over do and look at the wipe seal because it’s leaking water down bottom of shaft onto wood.
I did this years ago and wondering anyone can remind me how to.
Dan_Y
Oct 13, 2008
521
Hunter 36 Hampton
Hey Nick
i think this is what you need. It’s in paragraph 6.4 of the h36 manual. It’s on my to do list
dan
Periodically check the motor and control box electrical connections, remove any residue and cover connections with a small coating of grease.
It is recommended that you, once a year, disassemble the windlass and remove residue buildup. To perform this maintenance follow all safety procedures and com- plete the following:
• Using the emergency handle, unscrew the nut by turning the handle counterclockwise.
• Remove the drum, upper cone, chain wheel, and lower cone.
• Wash down with water to remove any residue • Coat surfaces with a light film of lubricant
• Reassemble the unit and tighten the clutch by turning clockwise (with anchor in stowed position).
