Hunter 18 Capsize
Feb 21, 2019
55
Marlow-Hunter 18 Cocoa, FL
I've found the H-18 to be a pretty stable boat - I've driven it hard in 20 kt winds and never gotten close to water in the cockpit. In a real knockdown I suspect the boat is self righting to a point beyond which it goes full turtle. Has anyone ever experienced a H-18 capsize that resulted in the boat turtled or past its self--righting point and if so, been able to bring it back up unassisted?
I'm considering some coastal camping/cruising and wondering if a masthead float is worth consideration.
3,676
Never sailed a H-18 but a couple of hundred dollars for a Hobie Bob seems to be prudent.
The boat floating on it's side is almost always fairly easy to right even if the centerboard gets retracted. Turtled especially with the board retracted it becomes monumentally more difficult and for a smaller person impossible. If you get the stick stuck in the mud, there is no way without the help of another boat to get it upright.
