How confident are you in your boat's 120v wiring?
Sep 24, 2018
4,821
Catalina 30 MKIII Chicago
I usually run a propane buddy heater and an electric space heater while working on my boat in the winter. This year, I'm 3ft from an outlet in the yard. I thought it'd be nice if I could use the outlets in the boat. I did an inspection on my '94 Catalina and found nothing out of the ordinary but bad connections can be hard to identify by eye. How common is it to find faults in the 120v wiring? Are you confident enough in your wiring to run an 1500-1800w heater for 6+ hours?
I'd prefer to focus on the electrical side of this as opposed to the dangers of running heaters in confined spaces.
Likes: JBP-PA
Sep 25, 2008
7,752
Alden 50 Sarasota, Florida
It worries me more to read questions or comments here written by people who clearly don’t ask such questions and don’t seem to appreciate the danger of ignoring routine inspection and maintenance, e.g., the “ where does this hose run”, “how is this wired”, “ how many thruhulls do I have” ….
To repeat a cliche, if you arent confident about it, it’s easy to fix that.
Likes: degas
Mar 6, 2008
1,532
There aren't many outlets in the boat. Open them up and see if they look normal. I like the wires wrapped around the screw rather than pressed into the hole near the screw. Test the GFI and use a tester to confirm correct polarity and properly grounded outlets. If you are not comfortable with the wiring then run the high wattage appliances using extension chord.
What gauge wire is your extension cord? It should be at least 12 for that wattage, 10 would be better.
How warm do the plugs get? It would be normal for the plugs to warm up a bit, but not become hot.
What kind of voltage drop occurs when the heater kicks on? And what is the voltage at the plug? Measure the voltage at the end of the extension cord and at the outlet the heater is plugged into, they should be the same. If they are not there is a problem in the system that needs to be addressed, most likely a loose connection or corrosion.
Check and monitor all the connections with an IR Temp Gun or an IR Camera.
Turn the heater off if you leave the boat for even a few minutes. Dress warmer.
Sep 11, 2013
252
Catalina 25 6106 Lake Erie Metro Park
When I rewired my Cat 24 I was horrified to find the connections at the inlet to the shore power cord were burned and corroded even though the load was fairly light, a small microwave and the house battery charger. If you have any doubts about the boat’s internal wiring‘s ability to power a high current load like an electric heater for a long period of time, then by all means, run an external extension cord. Did you ever see a fiberglass boat burn?
Tom G
  • Wow
Likes: degas
Jun 21, 2004
3,225
Beneteau 343 Slidell, LA
I second @dlochner’s recommendation to use a heavy gauge extension cord & do not leave the heater unattended, turn it off when not on board.
dLj
Mar 23, 2017
5,276
So you are thinking to run two electric heaters - Just a FYI, I've found often that a 30 service will often trip after a few minutes of running two electric heaters. If I were to be running two electric heaters, I'd want to run off two separate 30 amp circuits and I'd run each straight off an appropriate cable. If you have a 50 amp circuit that would work with one cable.
dj
Jun 25, 2004
674
Hunter 306 Pasadena MD
I'd sure be worried more about 20-30 year old wiring that's been living in a marine environment than I would about the same age wiring in a house. Just going on basic common sense, I wouldn't want to operate a space heater in my 22 yo boat plugged into the onboard outlets. So using an extra heavy duty extension cord, plus don't operate it if you're not physically there, both make sense to me. Better a small fire/melt down where you can see it than hidden behind a bulkhead.
I don't know the gauge, but I have one long extension cord at home that is HUGE and very, very heavy. It's what I'd go with.
Likes: Timm R Oday25
Sep 26, 2008
812
Hunter 340 0 Wickford, RI
A couple years back I spent the winter replacing my VHF radio from the cockpit to the navigation station inside the boat. It was a very cold winter and I did run an electric heater, smaller than you plan though 1000 W.
I found I did not need to run it for 6+ hours constantly. It got warm and I turned it off as I was moving around and turn it back on as needed.
Like you, I was only about 6 feet from the marine outlet, so it allowed me to use a shorter length extension to connect to my boats hull plugin connector.
I have 4 outlets in the boat. 5 if you count the one behind the microwave, but that isn’t possible to use.
Oddly they are all GFCI, but that‘s how it came when we bought it new in 2000. The only issue I had was getting an extension size plug in the outlet over the drop down mirror in the head. It was a very tight fit.
As mentioned above, From what I have seen of the wire connections on my boat they are all wrapped around the screws on the outlets.
And I agree, dress warmer and take off items as needed. You’ll be surprised as to how warm you do get moving around as you work.
So to answer your question…..I have confidence in my onboard wiring, but don’t over tax the system.
Sep 24, 2018
4,821
I dress as warm as I practically can. Heaters are ran on high for the first 2-3 hours and then I start to remove layers and turn them down after that
This is more of a general inquiry of what kind of quality or lack thereof, is common on the high voltage wiring on sailboats. To gain 100% confidence, would require a complete rewire. As we all know, there's only so much time to fix the dozens of issues that need to be addressed each winter.
Everything looks normal so far but I've encountered normal looking connections that heat up under load or are intermitten. I suppose a good middle ground is to reterminate an outlet or two and only use the heater on those outlets. The only other 120v devices I run in the winter are LED lights, a couple of USB chargers and an occasional dual battery charger.
GFCI's are kind of low on my list of concerns since I'm not using them around water. They trip easier than most breakers. I got screwed on a job at a brand new building recently. All the breakers were 20 amps but we found out the hard way that the GFCI's installed were only 15.
Most space heaters only use two prong 14 or 16 awg cords. Granted, the cords are only 6' to minimize voltage loss.
I run 12awg cords. In past years I had to run 75'. I was running them through the companionway. This year will be no longer than 25'.
Extension cords have run warm but not hot at the ends. I highly doubt the shore power cords will get warm at half capacity. The boat's 15-20A wiring is another story and should be checked under load.
Good call. I will measure this with the boat's wiring
Excellent idea!
For the first few hours I'm dressed in multiple layers. I usually switch to a different pair of shoes to keep snow and salt out of the boat. There's about a month in the middle of the winter where it's just too cold to work, no matter how warm I dress.
If only I could heat the bilge, engine compartment and floor...
Thank you for sharing your experience. This is exactly what I was looking for.
I have seen pictures of boats engulfed in flames but not in person. I did see the aftermath of one that burned down at our marina. There was nothing left but the hull and charred parts. It was pretty shocking
One electric heater. Two will trip a 20A breaker, even if one is on low. In theory it shouldn't have as the overall load was below 2400w. Perhaps the yard's panel isn't what it used to be
My boat has been on Lake Michigan all it's life. Copper wiring holds up pretty well around here. After 32 years, I'm just starting to see corrosion. Catalina used copper for the main battery and starter cables
dLj
Mar 23, 2017
5,276
As a general inquiry across all sailboats is an absurdly easy question to answer. There is as much variation as sailboats and sailing conditions mixed with their history.
But I really doubt that is your inquiry. Your inquiry as I understand it is: I'm going to be running 1 electric heater in my boat (it would be helpful to know it's rated capacity); I will likely run it for (maximum potential run time) hours; I'll be using it while I'm working on the boat this winter (if that is correct) - what's the best way to make sure my system can handle it and I don't risk burning down my boat or any other disaster that might ensue...
To that end, you already have a decent answer.
The answer to the general inquiry is - there is everything from totally unsafe and you should rip out the entire system and rebuild it - to - its rock solid and there would be no problem - along with everything in between ...
dj
Sep 24, 2018
4,821
Most heaters are in the range of 1500-1800w. I usually shut down the propane heater and rely upon the electric one after a few hours to help maintain safe oxygen/CO2 levels. In general, the heater runs for 6+ hours -- Quite enough time for the wiring to heat up if there's going to be a fault.
I think I will do a close visual inspection of my boat's shore power inlet, 120v side of the panel, the outlet closest to the panel and do a load test to monitor voltage drop and heat. I may test other outlets based upon a successful pass of the first and the way the wiring is routed (single run of outlets in series vs multiple branches).
Likes: JBP-PA
dLj
Mar 23, 2017
5,276
I have an 800 watt electric heater. I also have a 2600 watt electric heater and several 1500 watt electric heaters. All of them have a thermostat so back when I used them (new house, new lifestyle) i could just turn them on and let them run.
On my boat, I usually brought one of the 1500 watt units after discovering that bringing two of them was futile... And 1500 watts of heat was rather minimal for heating my boat in the dead of winter. We would have had similar winters i believe but my boat is larger than yours so you may be just fine with that size heater. It does matter if the boat is dead cold or if I've been heating it more recently.
I'd guess after an hour of running you will have reached close to steady state so checking connection/line temperatures after an hour should give a good indication of how things are running.
I do like doing voltage checks at various points along the connection path both open voltage and voltage under full load. Open voltage i do at the source and then at the point of use. If those represent a good number I don't check inbetween. Under full load I find to be a better check. But it can be a bit of a trick. I typically only check this at point of use. I usually use an extension cord at the heater that has several outlets. I plug the heater in one, measure voltage with it off, then turn it on and watch the voltage as it runs.Easy to just have my probes on my volt meter pushed into an open plug.
I don't have an IR temperature gun so I just feel the connections with my hands. Works for me....
dj
Sep 24, 2018
4,821
dj
The boat is usually dead cold. My boat shoes are usually ice cold as well. I might buy some heated socks because the floor is freezing! Every so often it gets the the point that I can't feel my toes! Heated mats take forever to heat up but then again, mine was only 120 watts.
I was running a 25' and a 50' 12 gauge, heavily insulated cord. A few times left it out and snow would cover them. I found it a bit humorous (although not exactly safe), that the snow would melt around the connection point of the two cords. I suspect broken wire strands and/or poor connections due to wear and tear. The cord leading into the boat had three outlets. One or two would be for lights and the other would be for the heater. I tried my best to keep the high load run short. On jobs where we have hand built extension cords with quality connectors and industrial grade portable cable, we rarely feel the ends get warm, even when it's loaded up.
Visual check is useless. Load and heat test very useful. Also check each connection. I pre-emptively rewired the connections from my incoming AC to the AC main breaker on my panel when the boat was 30 years old (10 years ago). Don't just look and check, redo where it's easy to get to and redoing your wiring at the back of the shorepower inlet wouldn't be a bad idea either. Good luck, keep ahead of it. Good that you asked. Don's first answer pretty much covered it, the rest were helpful details.
Sep 24, 2018
4,821
I agree! I mainly stated that I would do a visual inspection to keep people from telling me that I should do a visual inspection. @dlochner's suggestions for voltage drop and heat testing were excellent. I plan on testing from the shore power inlet to the outlet closest to the panel. I may do more outlets. We shall see
Mar 26, 2011
4,067
Corsair F-24 MK I Deale, MD
Before my daughter moved into my parents' 70-year-old house I opened every box. I replaced all of the outlets, added GFIs, and re-made many connections. Not hard. I found several serious issues, that would have failed in the next 1-20 years. However, the wire was still good as new, so complete re-wiring would have served nothing. The breaker panel and subpanels were less than 20 years.
Boats are different. Somewhere around 30 years everything should be checked, visually in some cases, tightness whenever possible, and re-made if there is ANY sign of corrosion. Not that hard, probably a day if no or limited components need replacement. The whole house took about 10 hours of work. A few more to add some new things she wanted, but that is different.
The rules for leaving things running unattended are still a little different from home. The boat moves, even at the dock. Less space. More combustibles. I would not leave anything portable running, and nothing that challenges the shore power.
While good advice, for those of us here in your PNW or our Pacific Southwest, the NEED for heat inside the boat while wintering-over in the water is absolutely necessary. With snow on the deck at 32F and water temperature at 47F, it will literally RAIN inside the boat without heat. Simple psychometrics.
Therefore, it makes it even more ESSENTIAL to confirm the stability and continuity of the entire system. In most cases, the wiring, even if old, is rarely suspect, but worth a check. How? When REDOING the connections which are ALWAYS worth removing and reinstalling, look at the end of the new bare wire you expose for the new connectors. Any green? Then work your way back until you find clean bright wire, or replace the wire while you're there.
Sep 11, 2022
145
Catalina 34 mk 1.5 Rockland ME
^^^^ this
I call space heaters "faulty wiring detectors" - along with electric cars and cooking appliances. Anything that pushes the circuit close to its rating (which is 1500W for a typical 120V circuit). I have melted several outlets and plugs in my life.
Identify every connection in the path. Feel the wire or plug near each connection after the heater has been running full power for a while. If you can feel any warmth at all, check and re-check. A little warmth is normal, but anything hotter than a hot shower would start to make me nervous. Remember the wires inside the plug will be hotter than the plug itself, and thermal cycling will make a loose connection looser.
  • Helpful
4,067
Let me put that a different way.
Shore power plugs that are loaded near their rated capacity have a disturbing frequency of overheating, resulting in failure. I would make certain my shore power was rated for at least 50% more than what the heating system drew. Same with AC.
We have cold here, but the water freezes, so reverse cycle doesn't work for heat. You need to burn fuel or use resistance, which really pulls the amps. I do understand the "rain" issue.
