Hi everyone. I am looking at buying a 423 (2007) Beneteau and would like input on a few items I've noticed prior to the survey. Like anyone, I want to anticipate and big surprises and the more input the better. I do know that wear and tear is normal, just want to know if these are significant...
1. The mast step appears to have a slight "cupping" going on (maybe 1/8") around the plate that attaches to the hull. Is that of concern?
2. The Keel Bolts are weeping a small amount and the two forward bolts appear to have had caulk put around them.. I know that won't actually stop water and that it is odd...
3. The Keel itself has rust in patches that are almost entirely on the forward edge.
Are these major concerns or things that maintenance can take care of? Major=more than $3,000 in my definition.
Also, what is a good way to check all these things and the hull grid? I will have a surveyor look, but want to be sure she is sound.
The forward berth has mold in the ceiling area, is that something that is difficult to clean up? Does the ceiling open (panels come off) fairly easily if we want to do it ourselves?
I've included a couple photos to get your thoughts.
Thanks!
Thanks!
