Sailboat Recommendations?
Nov 3, 2025
42
Spindrift 15 foot Great South Bay
I live on Long Island and am relatively new to sailing. Current use a 15 foot dinghy sailboat and now want something bigger as a day sailor. I am thinking of keep on a mooring and trailer at beginning and end of season. What Catalina would you recommend? Is a swing keel safe on a mooring?
dmax
Jul 29, 2018
1,343
Telstar 28 Buzzards Bay
Can't go wrong with a Catalina 22. No issues with a swing keel on a mooring.
What are the constraints that affect your purchase?
Boat size? Cabin for overnight sleeping? Price? Full features for camping in the boat?
Nov 3, 2025
42
I am new to sailing and most times my wife will be with me although some I may need to single hand the boat. I am a killer concerned with the swing keel - seized bolts crank handle and thought I read somewhere the winged keel fixed model is better suited for a mooring. Finally I am not sure if it is self bailing
dmax
Jul 29, 2018
1,343
A fixed keel is generally easier to deal with except for trailering. A swing keel can seize and it is a pain. For me, on a smaller boat a swinging keel would be preferred. As with everything, pros and cons. A Cat 22 cockpit is self-draining, it should have an automatic bilge pump for any water that gets in the cabin.
JBP-PA
Apr 29, 2022
804
Jeanneau Tonic 23 Erie, PA
Catalina 22's are great, but there are a lot of other options in addition to Catalina 22's. If you only launch/retrieve it once a year, you can get some better features, more headroom, a heavier boat with a shoal keel/center board, or even a trailerable pocket cruiser.
  • Helpful
For those of us who have owned one the Catalina 22 meets each and all of those criteria! :)
It's light enough to trailer, and heavy enough to keep on a mooring. It is stable to sail in heavier winds (4 years on SF Bay). It is roomy enough to sleep two comfortably, especially if you build the insert with the galley slid aft to make the entire dinette a berth and avoid the V berth - makes it more than camping. A pop top model also helps open it up when on the hook. We bought a 1981 boat in 1983 and it was still a good deal. Mark Is go for great prices are easily cleaned up if they only need elbow grease, and parts are readily available from Catalina Direct (even with CY closed down). Patrick Royce's excellent book, Sailing Illustrated, details the C22 and is a fantastic basic sailing book on its own, highly recommended.
I grew up boating on the Great South Bay. The bay is noted for being shallow with shoaling, a swing keel is an advantage in that kind of water.
All boats require maintenance and parts need replacing over time. The keel winch and cable are not for ever parts, they will need to be maintained and replaced. If you are looking at about that needs these parts replaced, then that should be factored into the selling price.
Nov 3, 2025
42
Wow thank you very much for taking the time to reply. Your recommendation are very much appreciated.
Oct 10, 2009
1,108
Beneteau 393 Muskegon
A Catalina 22 seems pretty ideal. I had an ODay 23 for many years that we liked because it had an enclosed head and felt a lot bigger, but they are harder to find. One recommendation, while it's important to make sure the mechanical parts all work - swing keel, outboard, especially - pay close attention to the sails. An awful lot of used boats are sold with rags, which add $3-5k to your purchase. Plus, old blown out sails reduce your enjoyment and increase your frustration.
Sep 17, 2022
213
Catalina 22 Oolagah
PConti2025:
Your question has been asked and answered over 16,000 times. If you consider the fact that many times a boat has had multiple owners, I am sailing my second C-22 and to my knowledge, I am the third owner of this great little boat. So the actual number of people who have happily owned C-22's could be two or three times greater than the number of boats produced.
Regardless of which keel design you decide on, you cannot go wrong with a Catalina 22. If you've found a 22 in great condition, don't wait too long. Someone is going to buy that boat for sure but don't worry, there are a lot of C-22's available on the used market. These boats don't wear out, they just get passed to the next owner as we either out grow and move up in size or grow older and age out of sailing.
George
Likes: Indysailor
dmax
Jul 29, 2018
1,343
Agree, one of the biggest plusses for the Catalina 22 is the incredible number of them that were made and the community of owners. Do not underestimate the value of this.
Nov 3, 2025
42
Ok. If I was to use the boat moored on Long Island then trailer it to warmer climates in winter months would a single axle trailer be sufficient. Would I need to upgrade trailer? Bearing buddies better tires? I will post this same question in Trailer Sailor forum. I want to find a way to extend my sailing experience as I approach retirement
Dave
Forum Admin, Gen II
Staff member
Feb 1, 2023
128
Please do not post duplicate or essentially duplicate questions in the forums. If a member does make duplicate posts one of them will be deleted.
We delete duplicate posts because they get confusing for both members and the original poster. It is much more helpful to have a single post on a question. Many of the most experienced members get notified of any new post or enter the forums from the "What's New" link which shows all new posting regardless of the forum they are located in.
Answer is YES. Real issue is TIRE quality.
I would trailer our C22 four hours north from SF to Clear Lake, California. A friend of mine pulled his from Chicago to Florida at least three times. I had a standard two axle trailer that came with my 1981 boat, #10496.
Sep 17, 2022
213
Catalina 22 Oolagah
Having towed both my previous 1974 C-22 and my current 1988 New Design on long cross country trips on single axel C-22 specific trailers, I can say it sure is doable. You do need to have the correct towing vehicle (which is not, per your other post up to the task). My only long trip with Waffle House was with a one (1) ton [3500] vehicle and I needed to fastidiously employ my cruise control to maintain a reasonable and legal speed. I will also say that I am not planning any trips from our current slip on a regular basis. If I were to make frequent future trips I would prefer a dual axle trailer for safety’s sake but a single axel trailer which is well maintained with proper tires can sure make trips of any distance. Safety favors dual axel trailers. They are not a must have but, they are sure the better way to approaching long distance commutes.
George
Sep 28, 2025
99
Catalina C 30 MK1 1983 Stockton Lake Missouri
Here is the sailboatdata information on 3 catalina 22’
Click on definition next to the different categorie for more information about the data
