Hunter 260 listing to starboard
Curwen
Jun 25, 2015
6
MacGregor 26D Saratoga Springs
Hello,
On Tuesday there was no wind and the lake temps were at 92 degrees, so we spent a lot of time in the water floating around the boat.
I have a 2002 Hunter 260 with a tiller and a 9.9 outboard.
While floating around I realized there is a real list to the starboard on my boat. Looks to be about an extra 2 inches at the waterline on the port side.
Is this normal considering that the outboard and both batteries are mounted on the starboard side?
Thank you. Still learning what is "the normal" on my boat.
dmax
Jul 29, 2018
1,328
Telstar 28 Buzzards Bay
Many (smaller) boats list at rest, generally because the design isn't balanced when fuel, water, batteries etc. are added. Can you swap your battery to the port side?
