Hunter 240 What is the best motor for a 240?
Jun 27, 2004
114
Hunter 34 New Bern, NC
I have a 240 without a motor. I would like electric start. what is best motor for this boat?
Hi, Ed, see you're in NC. What kind of waters do you sail on? Lakes?, bays?, ocean edge? That'll help us to help you. Also, do you have a range of hp in mind? Have you started to your own search for available models from Tohatsu, Mercury and Honda for electric starts? I used to own a C22 and C25 of SF Bay and both used 7.5 hp engines and were fine, so I'm guessing that or a 9.9 for you.
There are a lot of choices. Read reviews. BTW....I had an H26 and could push at hull speed at 1/2 throttle on a Tohatsu 6. You don't need to go any larger than a 6 for a 240. Some people here will talk about head wind and currents ...head wind might actually be a thing but currents not so much. Hull speed is hull speed regardless of current. I would recommend you stay at 6 HP or below. A smaller engine is easier to mount, burns less gas, easy to remove and bring home for maint... and weighs less on the transom. When I got mine, I was very interested in an OB with an alternator. But later I added solar so... that became less of an attraction.
Get the extra long shaft version of whatever you choose.
BTW: I really liked my Tohatsu. It was a pull start but it always started by the second pull.
Sep 24, 2018
4,451
Catalina 30 MKIII Chicago
To reiterate about @rgranger said, solar is far better than an alternator. Alternators dump a small amount of current and widely fluctuating voltages into the battery. It's just enough to start it next time.
I had a 94 4hp Mercury that was made by Tohatsu. I hated it. It always started but a few times it took me 20 minutes of pulling before it came to life. When I moved to a bigger motor, I didn't hook up the battery cable right away. I never thought that an electric start would have enhanced the sailing experience as much as it did. I also think it's good in emergency situations.
3,644
If you are tied to an electric start you are pretty much limited to a 9.9.
A six is plenty enough hp but you'd be better off going up to 8hp and getting away from a single piston motor.
3,644
Folks who bought the Honda had issues with the large cowl and tilting the motor up.
This question has been asked and answered many times check the archives
3,644
For kicks and grins, I looked at the Online Outboard website the 8hp Mercury is available with an electric start. The other awesome thing about the Mercury is the twist grip shifter. You can shift from forward to reverse by twisting the throttle handle back across neutral without taking your hand off of the motor tiller or your eyes off of what is around you. With one hand on the boat tiller the other on the motor tiller you can steer with both, and it really makes for some great maneuverability.
That feature makes the Mercury the best option.
May 25, 2004
973
Catalina Capri 14.2 1670 Rochester, MN
The first motor on my H260 was a 1hp Yamaha. This pushed the boat just fine in calm conditions. Any wind, boat wake, current and I didn't have enough power. I upgraded to a 9.9hp Yamaha, the max weight for my motor mount. You don't need more hp than that to reach hull speed. (Under 6kts) The real key to successful motoring these models was linking the motor to the rudder, so the thrust can be aimed.
I agree with what @Rick Webb said about being able to steer with both the motor and tiller. I would not recommend connecting the motor to the tiller but many people disagree with me on this one.
May 25, 2004
973
On the H240 and the H260, the motor is fixed in place. Does not pivot. There is no motor tiller. If there was, it would be unreachable from the helm station. That is why so many of us change it and link the motor to the rudder.
Sep 29, 2008
53
hunter 240 Dewey beach, De
I have been using a Mercury 9.9 Prokicker long shaft with electric start and power tilt for 4 years with no problemsd.
Sep 29, 2008
53
I have been using a Mercury 9.9 Prokicker long shaft with electric start and power tilt for 4 years with no problems. on my 1998 240. Also have remote shifter which means on messing with the tiller.
Sep 15, 2018
19
Hunter H240 Richmond
I have a Mercury 8hp electric start with alternator. I think I got 15 mpg on the Erie Canal. Very efficient and the alternator kept the lights on. I can easily control the motor by hand from the cockpit and mine has wheel steering. I find the 8hp four stroke to be all the power I need.
Sep 17, 2022
195
Catalina 22 Oolagah
The big advantage of a 9.9 Prokicker is that transmission control is available on the throttle. This allows you to shift from forward to reverse without removing your hand from the throttle. I think its a huge advantage while docking to be able shift into reverse without looking back at your engine.
George
