Invest 98L --> TS Melissa --> Hurricane Melissa
JamesG161
Feb 14, 2014
7,912
Hunter 430 Waveland, MS
All models are to many days out to predict this Tropical Wave, but....
GFS
ECMWF
It runs head on to Dry Air and should weaken.
Dammit Jim...
Likes: Gene Neill
"Something wicked this way comes."
Perhaps the lack of storm excitement this year has the internet buzzing about 98L and what it might be—what it may become.
98L will certainly become something. The weather front (not yet a tropical storm) is trapped between two high-pressure cells and is stalled (temporarily) in the Caribbean Sea. The water temperatures are ripe for storm development.
This morning's observation provides two possible developments based on the GFS and the ECMWF weather models.
The GFS model predicts that the storm will form over the next couple of days and then track NorthEast. The path has the storm track over Hispaniola on the 27th and out to sea.
The ECMWF model indicates the storm forms but is delayed in the Caribbean Sea for 24 hours. It then tracks north over Cuba, out over the Bahamas, and to sea.
We need to remember this is weather, and it may do something that the models are not predicting. Whatever path it takes, the storm will be carrying a lot of moisture. Expect heavy rainfall and flooding to be associated with this storm.
Listen to the advisories of the local officials and stay safe.
Likes: JamesG161
May 1, 2011
5,214
Pearson 37 Lusby MD
Looks like the bulk of the models show Melissa staying away from the East coast. One model shows that it could drive some much-needed rain for us.
Likes: JamesG161
JamesG161
Feb 14, 2014
7,912
Hurricane Hunters now
Dammit Jim...
The Plane, the plane...
Earlier, there was a discussion of the storm not forming vertically due to a tilt in the axis of the storm. It is over warm water, but the lower half is being blown towards the west (influenced by the Trades), and the upper half is being blown to the East by the tropical jet. This tilted access can be seen in the reported wind speeds, which are displaced to the east of the storm front (the 40-50 kt winds yellow and light green).
This is a good thing, but likely not lasting over the next 24-36 hours.
Keep tuned to this channel for updates.
Likes: JamesG161
JamesG161
Feb 14, 2014
7,912
Well Mellissa is hovering to remove some stored SOLAR Energy.
Note: this is NOT surface temperatures.
This describes depth of Stored SOLAR Energy or HEAT.
GFS Model :yikes:
DAMMIT Jim...
Good Monday Morning.
Over the weekend Melissa has organized into a dangerous Hurricane. The NHC is forecasting a 4-5 class storm. The models are now agreeing on the probable route taking the storm in a NE direction across Jamaica, Cuba, likely the Bahamas and Bermuda into the North Atlantic. Not a good time to be trying a late crossing of the Atlantic as the storm will be large and affecting the passage routes.
Here is the NHC global model guidance from today.
JamesG161
Feb 14, 2014
7,912
Cat 5 storm now very scary
and
I went to Jamaica once.
Best spot to be was high in the Mountains.
All weather forecasters just moved West to avoid the scary landfall at night.:yikes::yikes:
Pray for all of them on East coast.
:pray::pray::pray:
Jim...
JamesG161
Feb 14, 2014
7,912
Major infrastructure damage in low lying Jamaica from storm surge. One death reported so far.
This will demo why Melissa is turning.
also HEAT changed to rain below
Jim...
