I’ve read threads about stinky hot water, I’m just checking to see if I understand them.
Stinky hot water, with no other obvious cause, is almost always an anode. Replace the anode and your problem is solved. The Seaward S-600 does not have an anode, BUT there is one on the market. You remove the drain and screw in the anode into that space.
My understanding is that this would be too late. The smell is the tank rotting, so an anode might have helped a few years ago, but not today.
Am I right so far?
not sure how old the tank is. The first two owners kept pretty good records, no records after that. It could be original to my 1995 boat.
Possible confounding factors:
Does it smell like sulphur?.
No, I can’t describe it. Just smells bad. Wife says it smells like the antifreeze we bled out of the lines in June, but I don’t think so.
This spring when commissioning the fresh water system I got frustrated by how often I was cleaning the screen (filter), so I just removed it, thinking all the gunk would come out through the faucet with the diffuser off. But I misread the system a bit, and realized that now all the gunk was going through the water pump, and then the water heater. Not sure how long until I realized my error and put the screen back, not sure how much gunk.
I thought maybe draining the water heater might help. when I open the drain I don’t get 6 gallons of water. I get maybe a quart. Not sure what to make of that. Yes I understand gravity! I’m keeping the hose below the level of the drain.
Am I right so far?
