My track is coming apart. The plastic extrusion is separating between the outside track that the sail slugs ride in and the bead that runs inside the mast slot. Where can I get a replacement, and how hard is it the install? If you zoom in on the first picture you will see the problem above the spreader. The second picture is lower on the mast. Thanks.
