I'm motivated to move some instrumentation around. The main issue I am trying to rectify is the fact that the current Admiral engine panel is located near my feet when at the helm. Currently, it is pretty difficult to read anything on this panel. (The position is indicated in orange as "Panel" below.) I want to move it to the position indicated in red as "New Location".
This solves another problem I have. The windlass switch is located in a position I frequently active accidentally when backing out. (I like to sit with my back to the portside coaming so I have good visibility both directions and can easily reach throttle and steering. But, on more than one occasion, I have let out a bunch of chain because I neglected to shut off the breaker to the windlass.) So, I would relocate the windlass switch to a point aft of the AP and as high as possible. This is in a better position anyway because, when anchoring, I am more likely standing right there so I can see forward better.
I'm just doing a sanity check for considerations I might be overlooking. Seems pretty straightforward, but ... boats.
The fuel shutoff cable probably needs to stay put. It is near the upper portside corner of the panel (just barely visible below the green arrow below). It doesn't bother me there and I think it might not be feasible to make that 90 degree bend if I were to move it with the panel. And, aside from relocating the windlass switch, I don't think anything else has to move.
Then, that gives me a panel-sized opening in the aft side of that port locker. I think I might just glass in a little cubby hole there for storage. It could be a good location for an auxiliary VHF mic or just a place to keep sunscreen, or both.
Any words of caution about things I might not be considering?
