Okay, here's an idea I've seen comments on, and wondering if anyone can give some real-life experience on their boats...
Background:
I have recently, due to major work, separated the hull/deck joint (removed all 14,278 bolts!). The rub rail was bad, beat up, and falling off...to be replaced...so I just pulled it off and found that the PO's had goobered goopy stuff in various places under the rub rail on the joint, I'm assuming to stop leaks. So once I started looking, I thought it might be a good idea to check the whole thing out, and that's how I ended up taking all the bolts out...
Found that the oldest-looking bead of sealant in areas with no obvious goopy-goop nearby, which I'm assuming was the original from the factory, was just that, a small single bead of sealant between the deck joint, and a ball of sealant at each bolt. It did not look substantial to me, and it was dirty, dry, and I would like to replace it with something more substantial, but am not convinced (yet) that trying to put a bead of anything in there is the best way.
In my head, I'm thinking that it needs to be flexible (because the hull does flex), and thick enough that when the two flanges are pulled together it will fill up any bumps and surface irregularities (and the surfaces ARE irregular). I also think it should go for about the whole width of the two joint flanges (about 3/4" to 1" wide) so it has enough chance to seal against most of the surface.
Someone mentioned that they had found a "strip" type of seal, like weatherstripping, in that joint. The more I have thought about it, that doesn't sound like a bad way to go, and might be easier to be sure it seals. Any experience with this you can share please?
Background:
