Wrong dilution posted, not 25%, 25:1 oil/gas mixture used.
I bought a new, unused Merc (2005) 9.9 2 stroke and it leaked oil after running a 25% gas/oil mixture for the break in period. After a run on my sailboat, I returned to the dock and it was discharging oil from a small hole on the starboard side just above the lower end.
I thought it was gear oil. I took it to a dealer (merc) and after a $130 assessment they said it was engine oil and it was due to running the oil rich mixture. The removed and pressure tested the lower end. They said it was ok and looked like a new engine.(it is)
Well, it happened again with a regular mix.
Any ideas or info on this condition would be appreciated.
I would like to know where and how and why the oil gets to this discharge "hole".
Thanks in advance.
Added a photograph... it is hard to see but look above the gear housing... Just above the line is a small hole...
Thanks in advance.
