Re: I have done this job - twice!
Thanks, Murray.
Found it and here it is (just copied and pasted it). I also learned that when I click on your name on the recent post, I could find all your prior posts.....
Quote
I have repaired both my fixed ports on my B352. You need to remove the plexiglass, and scrap and sand (lightly) off all the old adhesive, of the frame and the glass. Get two tubes of Dow 957 (black) and the primer - you'll require one tube of 957 per window. Mask all around the frame (inside and out) and the window. Now the tricky part. Insert some small lifters (1/8") and float the glass on the 957 (the whole tube), push down on the glass, squeezing out the excess 957 - down to the lifters. Now remove/clean away excess and get a smooth bead around the frame/window gap. Do the same on the inside. Carefully remove the masking tape right away (fix the bead, if necessary). Put a little weight on the window and leave it alone for a few days. I think it is easier if the weather is cool, as it gives you more time to work the 957 - also you'll need about six hands to control the mess. I hope that helps. Let me know if you have any questions.
Murray
Unquote
