ODay quality
22
ODay 31 Nanaimo
I am looking at an 1987 ODay 31. Does anyone have a comment on this boat or on ODay boats quality in general?
Jun 12, 2010
936
Oday 22 Orleans Marina, NOLA
Survey of course, but regarding ODay in my research they are highly regarded and well built boats.
Apr 22, 2012
22
ODay 31 Nanaimo
Hi Denise
Thanks for the input. Yes, survey set up for this Thursday. Heard blisters can be a problem. How is yours for blisters? What engine do you have? How is it?
Jim
Harlan
Jun 4, 2004
99
Oday 34 Niantic
Old boats like old houses - depends on PO's maintenance. Wet deck core can be a problem. Be sure surveyor looks carefully. Most deck fittings were just drilled/cut and bedded - core was not removed and sealed. That's probably the biggest potential headache. I don't think blisters are a predominant problem. Deck can be fixed depending. I have friends with a new Beneteau (2005?) who have repeatedly said they wish they had their old (mid 80's) OD31 back - it had fewer problems!
Jun 12, 2010
936
My current understanding is that common blisters involve only the gelcoat and are nothing to worry too much about. There may be differing opinions. My boat had some blisters that were deeper than the gelcoat, under the first layer of glass, so I repaired many of those. Hope the survey goes well.
Oct 12, 2011
17
Oday 34 Dealle
It is my opinion that the pre 3 digit numbered boats were built better than the ones built after the company was sold to ( was it AMF) a large comglomerate. Look at the 30 and the 34 for nicely thought out designs and interiors with enough room, cockpit and interior, for real comfort. Plus they have a nice classic IOR look.
JB
Dec 14, 2009
63
Oday 37CC Norfolk, VA
Pretty solid boats - I would consider deck delamination the biggest thing to watch out for. I've done some repair on ours in the bow. The chainplates are solid and secured on large tabs below the settees in the cabin on the 37. We just repowered w/ a beta 30 and it rocks.
Jun 14, 2011
277
Hunter 22 Fin Keel Lake Martin
My hull is very solid, the deck does have issues but that is next years fix. I've heard nothing but good about O'days before and after I bought mine.
Apr 17, 2010
32
oday 35 Edgewater Md.
I hit a submerged tree last week in the Chesapeake bay that shook the boat and not a mark on her. I am planning on taking her with me when we retire
Apr 22, 2012
22
ODay 31 Nanaimo
Survey went well. No blisters. 21 minor problems with moisture on deck.
But found diesel in bilge. Mopped it up and ran engine. cannot find leak in hoses or tank.
Next day more diesel in bilge - a mystery. What is cost to replace aluminum tank? Have to move engine forward to get tank out.
Jim
Oday 35 and Mariner 2+2 Alexandria, VA
There is a hump between the engine bilge and the main sump. The diesel may have been spilled and has pooled in that space (pull up the sole in front of and under the companionway ladder). With motion it will flow into the main sump. With any luck that is where it is. It could be a cracked vent or fill line or a pin hole leak in the return line. Good luck.
22
ODay 31 Nanaimo
Have decided to proceed with purchase. Got reduced price to compensate for diesel leak issue. should close sale soon and will start looking for leak and fixing other issues.
Apr 22, 2012
22
ODay 31 Nanaimo
doesn't appear to have pan under engine? rib should catch leaks but somethings amiss
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
check your water separator fuel filter, the drain screw could be leaking. How much fuel is in the bilge, a lot or just a film on the water? An extremely small amount of fuel will create a sheen on the water. Regardless it is illegal to discharge overboard so it must be fixed, big fines involved.
