400w Inverter Show Fault with TV Plugged In...
Sep 2, 2011
1,041
Hunter 27 Cherubini Alum Creek State Park
...but not even turned on.
If I have the charger on the battery bank (two 6v 230a/h in series), everything works just fine, but even at 12.88v w/o the charger connected the inverter defaults to "fault". TV is 19"LCD with max power consumption of 52w. But like I said, the TV is not even on.
Please help.
Jun 6, 2006
6,990
Are the AC outlets wired correctly with hot on the left and neutral on the right and ground below (when looking at them)?
could be the TV has a polarity plug for a reason and the inverter is smart enough to figure that out.
What happens to the fault when you turn the TV on? does it work or not?
Sep 2, 2011
1,041
I'm plugging straight into the outlets on the inverter - polarized outlets.
The tv's red power indicator light is lit, but the green "on" light won't light when I press the power button. It's tripping the breaker in the inverter just with the wattage needed for "standby".
Btw, it's a cheap automotive inverter, but it will light a 75w light bulb.
After charging the bank overnight, the inverter/tv worked for a few minutes until I switched on the battery switch for the boat's circuits. Just the added load of the panel backlights and voltmeter tripped the fault. OCV, once I switched off and unclipped the inverter, was 12.9v
I might look into tapping into the tv's stepdown transformer (if it shows that the tv's circuit voltage is 12v) and just eliminate the inverter.
Jun 6, 2006
6,990
Is this thing powered by a 12 volt cigerette lighter plug?
Clearly you have what would be considered "sufficient voltage"
I suspect corrosion at the plug or where you are connecting it to boat power. with the battery charger on it is probably sensing the load and provide 14.4 which is enough to keep the inverter happy iven with the bad connection.
Everything should be clean and bright.
A positive check is to probe the inverter power leads when it is supplying power. That's why multi-meter probes have points on them.
Jun 6, 2006
6,990
Don't poke your finger when you probe the wires (don't ask). ;-)
Sep 2, 2011
1,041
The inverter is clipped directly to the battery posts via spring clips. I did probe the leads - 12.9 v.
This may al be moot. An electrical engineer acquaintance is going to bypass the tv power supply and convert the tv to 12 v input. Still, bugs me I don't know why the fault.
Sep 5, 2007
689
MacGregor 26X Rochester
Could it be discharged capacitors in the TV that put a very large but very brief load on the inverter, causing it to trip?
Jun 6, 2006
6,990
is the 12.9 volts while the inverter is running?
Jun 6, 2006
6,990
Here is my thinking.
It works with the charger on so having 14+ volts makes it work
it does not work when just 12.9 volts is pressent from the batteries (no load voltage)
A loose or bad connection at the batteries will read 12.9 volts at the clips when no power is being drawn but show enough voltage drop to trip a fault when some load is drawn. At 52 watts for the TV that would be something more than 2 amps which would suggest that running just about anything with the inverter should also cause a fault.
Have you tried other AC appliances to see if it is the TV or the inverter?
Sep 2, 2011
1,041
I measured 12.9 v with the inverter connected to the battery, but honestly don't remember if it was on or not. I do know nothing was plugged into it. I'll take a reading tonite when I get home with the inverter on and the tv plugged in. The only thing I've tried other than the tv was a 75w work light. I'll plug my laptop into it, but I don't think I have any other appliances that consume less than 400 w. maybe the coffee maker .
Sep 2, 2011
1,041
Ok, so I get home from work and get into the boat to do some testing.
Here are the results:
Air temp = 30*F
12.91v - after 8 hrs rest following overnight charging
12.91v - with inverter connected to battery terminals, switch off
12.90v - inverter switched on; no load
91v AC - at inverter outlets
12.87v - after 5 min w/ inverter switched on. Plugged in tv, no fault, turn on tv
12.74v - after 10 min. of tv watching
12.61 - after 15 min. of tv watching
12.60 - after 23 min of tv on; switch on battery switch to energize electrical system
12.60 - after switching on distribution panel
12.54 - after turning on cabin lights
12.50 - after 1/2 hr of tv and 17 min of cabin lights on
Now I'm really confused. Could it have something to do with the air temp,or did I just have a bad connection at the battery this morning?
I'll test it again tomorrow, adding a coffee maker to the mix, and report back.
Sep 28, 2008
922
Canadian Sailcraft CS27 Victoria B.C.
For one thing I doubt the TV likes running on a voltage as low as 91.
Sep 2, 2011
1,041
I'm not real confident that 91v reading is accurate. My good multimeter doesn't seem to have an AC Volts setting, and I couldn't get an understandable reading with it, so I grabbed a real cheap one I had, and that's what it read. I need to dig out the instructions for my good meter and find out how to take AC voltage measurements with it.
Anywho, the tv appeared to work just fine, but I'll bet it was cursing me for not feeding it adequately. dI don't intend to oprate it for any length of time at that voltage.
Feb 8, 2009
118
Sabre 34 MK-1 Annapolis, MD
I wouldn't place a really high confidence in that number.
Most volt meters, even decent ones, read peak AC volts and derate the nubmer to reflect RMS (Root Mean Square) volts. We use RMS volts for AC, becuase it is a reflection of "apparent voltage," or "useful voltage" and is essentially an "average" of the AC sine curve (which hits zero volts 120 times a second -- but we know "zero" isn't the answer either). What we call 120V is really closer to 200V at the peaks, and the volt meter just scales the peak down to 120V.
Inverters, anything other than "true sine" inverters, give an output that approximates a sine curve. But the curve is a bit choppy and squared off, and so the full peak doesn't show up. Since the top of the curve is more like 180 than 200, the volt meter will scale down to a lower number.
Note that the output of an inverter, while not making the same peak voltage as house current, does make the same RMS voltage. The typical volt meter just doesn't have a computer inside to determine what the RMS voltage output is. Also, the vast majority of devices, even "sensitive" items like computers and TV's, and even rotating machinery like drills, all work just fine with the modified sine wave put out by an inverter. Volt meters are one of the few things that don't work well on modified sine inverters.
You can buy "true RMS volt meters" and they will say it twice -- once on the box, and once on the price sticker!
Harry
Sep 2, 2011
1,041
Thanks Harry.
It's comforting to know I dont need to throw away my cheap little inverter. I have decided, tho, to invest in a 12v tv rather than rely on the converter with its fan coming on every few minutes.
11,709
Harry
With our old Xantrex I had some power tools that would not even start. You physically had to hand spin the drill to get it going. Once going it worked, but the motors sounded "off".
The real danger is that many sensitive items like battery chargers get tricked and they don't know when to turn off. I ruined a few hundred dollars in camera, iPod and tool batteries before wising up and getting a Pure Sine inverter and my batteries no longer cook.
In the first year with our iPod (gen 1 purchased in December 2001) I was plugging it into the inverter for charging as DC charge adapters for iPods were about $80.00 at that time (today they are $3.99 at the Dollar Store). That battery lasted less than a summer. Apple replaced it and in 2012 that battery is STILL working to this day. I suspect because I have not tried to charge it with a mod or square wave inverter since killing it, in a few months..
That MSW Xantrex ate a shaver battery, multiple DeWalt batteries, iPod, and four Nikon batteries for SLR cameras... Xantrex kept telling me it was fine....:doh:
Macgregor 21 MN
I've run a large TV with my rather cheap 300 watt inverter when the power was out at my house last winter. Using the same hookup I had on my boat, it was hardwired to the battery terminals. I don't like the iffy connection alligator clips provide. Remember volts X amps = watts. There's a big draw of amperage off the battery and a little bit of corrosion will cause a fault to be set. I've had it happen to me.
I've read in many places it's not good to charge rechargeable batteries off a square wave inverter. I guess that might even go for laptops, too, although I've haven't had an issue with my 5 year old laptop battery so far.
Jun 6, 2006
6,990
If the inverter has a standby mode you will most likly not see the full 120 volts on any outlet till you start drawing power from it. The real test is with power flowing from the inverter (tv on) what is the voltage from the outlet?
I suspect that you had the clips to the battery not making a real good contact (now they are) and that caused the inverter to "see" a low voltage fault condition.
or gremlins
Sep 2, 2011
1,041
or gremlins
That's an explanation that makes sense. Now that I'm done testing the inverter to see if it works, I will hard-wire it into the system. Should I put it on its own breakered circuit, or use an inline fuse?
Sep 2, 2011
1,041
I plan to use my 12v accessory outlets to charge iPad etc. the inverter would just be for any unplanned for 120v devices.
