The teak steps (boards) on the edges of the cockpit were not the best looking and needed to be refinished.
I decided to take them out and strip the many layers of varnish plus Cetol plus whatever had been layered on them over the years.
Once off, I realized it would be just easier to make new ones.
I had a plank of Ipe that I shaped taking the old boards as templates. Split (very hard wood with pollen like dust) and planed, and grooved using the blade on the table saw. I attempted to machine the lines with a round bit but that didn't go too well. This wood is so hard that even with small passes the brand new router bit would jump so I decided to just keep the square blade groove instead of the U.
I gave the back side a couple of coats of clear epoxy, bedded the boards in silicone screwed them down. Actually before that, I repainted the whole cockpit after filling the old screw hole, fixing the cracks and filling in where I took the old "city" water intake fitting as I don't foresee using it.
The only thing I used on these new boards is "teak" oil which is probably lemon oil with UV filter.
They're a little dark but it sure looks better than the old ones.
