As discussed in earlier threads I'm replacing these tangs with a different design:
Here is the crazy way the mast was originally set up.
There was a hole for a compression tube but no tube. The through bolt bushings were bearing entirely on the S.S. spreader mount so all of the strain of the lower shrouds was being carried by the rivets.
I can't insert a compression tube taped to the end of a stick as is often done unless I totally un-wire the mast and remove all fittings. Even if I could, the tube would bear on the aluminum walls and the space between the spreader mount would let the wall deform and crack under heavy load and bolt tension. Not good.
I need to put the tube in like this with the ends shaped to bear against the S.S. It is both an angled and curved surface.
I've drilled out the rivets and removed one mount and can do the other. What now? There has got to be a better way than trial and fit of something I can't see. A tiny bit of over filing and I'll have to go back to Rig Rite for another $40 compression tube (couldn't find this size at the usual sources).
Any ideas?
(I already know how I'm going to do it but the mental exercise was so much fun I thought I'd give you folks a chance to experience it.)
Any ideas?
