Muffler question
156
Hunter H33C Quincy, MA
Well, with the snow and ice almost gone I finally got to workin' at the Spring project list. I got the old fuel tank out, and with a bit of cussin' contorting got the plywood shelf out. To my surprise I do have a muffler! (some may recall my unenlightened questions about mufflers and if my boat should have one - the engine seems loud, so I didn't think I had one) it's not the kind I would expect; it's seems there are no connections for water, I thought there would have to be provisions to drain water from the exhaust. The muffler is a "Trimax Silencer" (I think), made by Marine Mufflers Inc. Is this a "proper" set-up?
Blaise
Hunter 37-cutter Bradenton
The water is injected into the exhaust at the exhaust elbow, not at the muffler.
Sep 3, 2010
69
Hunter 37C Annapolis
I am curious here. . .When I recently repowered the mechanic said I did not have a water lift muffle, but rather just a muffler. Was that the way it came from the factory or did someone mess with setup?? He added a water lift muffler and left the other muffler in place for increased quiet.
The H37C came stock with just a stainless steel horizontal muffler. And its not the most quiet exhaust. When I have to replace (as Ed S. recently did) I will probably go with a Vetus waterlock muffler. Which has a drain, unlike the original.
May 31, 2007
783
Hunter 37 cutter Blind River
My H33 had a water lift muffler. I suspect it was original equipment. No idea now what make it was. And there was no drain. As Jim mentioned, the 37C came with a horizontal Haven't really noticed much sound reduction.
Blaise
I have a vetus waterlift muffler (22yrs old) that does not have a drain. My exhaust with my 3gm30f is very quiet.
Sep 3, 2010
69
Thanks. I know I replaced the original muffler about two years ago. My mechanic was surprised there was no water lock muffler on the boat considering how low to the water the exhaust is. Frankly I am more comfortable with the water lock. Have to think about draining it come fall next year. I hope things are a bit quieter with the new engine. the old 3QM30 really put out a racket
Feb 14, 2010
156
should I change out the muffler to a water lift type? what is the best model for my boat (1981 33C)? if the boats were originally equipped with a water lift muffler, where were they located - under the fuel tank, or just aft of the mini bulkhead aft of the fuel tank?
Paul F
Jun 3, 2004
827
Hunter 1980 - 33 Bradenton
Please read about my experience last year with the 33. The title is "Warring Bad Exhaust Design" that says it all. You must have a water lift muffler and a loop in the exhaust hose to prevent water from backing into the engine and destroying it. The original exhaust layout along the bottom of the boat is bad as it allows water to directly enter the engine. here is a link to the thread.
http://forums.hunter.sailboatowners.com/showthread.php?p=775279&highlight=exhaust
Feb 14, 2010
156
Re Muffler question
Thanks Paul, I guess it's good to learn all this while I have things apart. . . I looked at the thread you have a link to - is that the water lift muffler to the stbd of the tranny? (a square looking box) So it seems that Vetus is the recommended muffler?
Feb 14, 2010
156
Re Muffler question
thanks Johnb. . . I love learning! (and I have so much to do!)
Jun 4, 2004
834
Hunter 340 Forked River, NJ
Muffler
Both of my sailboats (1980 H30 & 2000 H340) have a horizontal "muffler" installed behind the engine. The engine and muffler were above the loaded waterline and this design was factory installed.
On my old boat H30 (2QM15), the original muffler was a SS, horizontal muffler with a 2" inlet and outlet. It began to leak after about ten years and Hunter Marine advised me to replace it with a Primex fiberglass muffler replacement from Marine Mufflers (http://www.foreandaftmarine.com/MC-0300001.htm). When I installed the new muffler, it was clearly marked to position it horizontally but with one side facing up. I have to believe that there were internal baffles to trap the water and prevent back-flow. The natural flow and pressure of the exhaust forces the water up and out of the exhaust pipe. When winterizing the engine, I always waited until the exhaust turned the color of the antifreeze solution, ensuring that the muffler was protected. My newer H340 (3GM30F) has the same horizontal, fiberglass muffler installed by the factory. It runs quiet.
May 31, 2007
783
I would suggest spending the extra few dollars and get a water lock rather than a water lift muffler. Less chance of backflow to the cylinders and comes with drains for winter prep.
Feb 14, 2010
156
I didn't know there is a difference, I thought the terms were interchangeable. . is the only difference being the ability to drain the water lock style?
May 31, 2007
783
Perhaps you are right. I have just spent some time googling to find the difference but was unable. Perhaps I was mislead in the past or didn't understand. I thought the waterlock prevented flow back through the exhaust whereas a water lift just silenced the system by passing gasses through a water filled container. I am sure someone will enlighten us one way or the other.
Mar 22, 2004
733
Hunter 30 Vero Beach
Just a couple of quick questions on mufflers and exhausts.
1. What is the difference between a muffler and a silencer?
2. Can a water lift muffler exit the boat at or below the waterline?
3. Like sandpiper asked, What is the difference between the water lift and the water
lock muffler?
4. Most of the mufflers I found have inlets/outlets that are too big. Is there a reducer that will work to fit my exhaust hoses?
I tried the link to the practical sailor article, but it said that the link wasn't found.
Feb 14, 2010
156
Re Muffler question
Long story short, I had Centek make me a custom fit muffler.[/quote]
Did the custom muffler have a drain? Does anyone know if the stock Centek have drains?
