Interesting Stuff!
What's the ampacity of the batteries? How much current do you pull at, say, 5 knots? I'm thinking a 15A charger is pretty small - how long do you recharge after a couple hrs of motoring? I assume you have some method of keeping track of how much power you have left in the battery bank?
The batteries are 105Ah, so they should fully recharge overnight.
I do not have the motor perfectly aligned yet, so I have not
really pushed it hard for any length of time. At this point,
I have no way of monitoring amp draw or battery reserves,
other than simply checking the voltage of the bank.
Others with similar set ups have reported drawing 30-50amps
at 5 or 6 knots, so we would likely be out of 'juice' after
two hours of motoring at speed. I have no expectation of
motoring for hours on end. We have a quick and responsive
boat, and only intend on using the 'auxillery' to get in and out
of the slip. We literally only need about 30 seconds of thrust
either way, and are often able to sail in and out of the slip.
It is just assuring to know we have a little boost available
in a split second if we need it.
