Singlehanded anchoring strategies
154
none none LA
Our usual anchoring drill is for me to be at the helm getting the boat into position, with my wife on the bow ready to drop the anchor at my signal. Weighing anchor, we reverse... she motors towards the anchor while I pull it up. Breaking the anchor out can bit tricky, because if it's set well, but we're only in 7ft. of water, once I get to the end of the nylon, there's still 20ft. of chain in the water (a very short scope, but not nearly as easy to break it free as it would be if I were right above it).
Anyway, for the cruise we have planned for this Summer, I'll be doing the first 2 days and the last 2 days singlehanded, which will involve several instances of me having to anchor alone.
I'm not terribly concerned about anchoring... I figure once I've reached my selected spot, I can put the boat in neutral, scoot up to the bow, and drop the anchor once forward movement stops, then pay out the rode as the wind pushes the boat back.
Retrieving has got me worried though. The only thing I can think of is to activate the autopilot to hold a heading into the wind, put the boat in gear with just enough throttle to barely move the boat forward, then go up to the bow and pull the rode in (possibly cleating just before the chain comes up so that I can go back to the helm and break out the anchor before continuing). I'll then have to quickly secure the rode and anchor so that I can get back to the cockpit before something bad happens. If I do this, I will have a handheld VHF attached my inflatable PFD, just in case I fall overboard.
The other option would be to remove the chain and go with an all-nylon rode, which I could presumably then lead back to the cockpit to retrieve the anchor from there. But this doesn't seem significantly less risky than the first method, since I'd have to go forward while underway to stow the rode and secure the anchor.
Any other ideas?
--Michael
Jun 30, 2004
446
Hunter 340 St Andrews Bay
On the 310 a Stern Retrieval might work. Go forward and bring rode to stern, cleat on stern for safety. Back up to the anchor (slowly and being very aware of potential screw wrap). When you most of the rode in the cockpit, go to neutral and retrieve the anchor.
Second option is to bring the rode through the bow roller back to the cockpit where you will be at the controls. If its muddy you might end up with a dirty deck, but a bucket can take care of that.
higgs
Aug 24, 2005
3,704
Nassau 34 Olcott, NY
What I have done is to move the boat forward, go into neutral and move up to the bow to bring in the loose rode. I do this until the anchor is directly below the bow and then haul it in. I have always had enough time to bring the anchor up and still get back to the helm to motor safely out of the anchorage. It really has never been a problem.
Oct 28, 2008
154
none none LA
I wouldn't mind deploying and retrieving from the stern, but I think I'd have to get rid of the chain. In November there was a tropical storm inbound, and even though it was not much of a thread our marina freaked out and ordered a mandatory evacuation. So, I moved the boat to a bayou, with the bow secured to a couple of trees, and two anchors (including my main anchor which is usually on the bow) set out from the stern. Retrieving this anchor afterwards and then moving it and the rode to the bow was really tough, particularly due to the heavy chain.
--Michael
Don't remove the chain. We have 50 ft of chain with 1/2 inch rode above it.
Assumes you don't have a windlass:
Singlehanding has two distinct and different approaches.
1. If it's not windy it's a piece of cake. Grab a coffee, go to the bow and start hauling the rode. Bit at a time, no strain, until you can get the chain up on the roller and can get as vertical over the anchor as you can. This could take 15 minutes or less. Wait a bit and haul some chain. Once you're above the anchor, it won't pull up by hand unless it wasn't set right the night before. Cleat it off with a chain hook and slowly motor over it. Back in neutral, go forward and pull it up. Easy.
2. Windy. Harder. Depends on how windy. Light wind, same deal as above, takes a bit longer. Stronger winds: run up on the anchor maybe halfway, haul rode. Do again as necessary. Before you do, figure out the heading from the bow to the anchor and when motoring forward go 10 or 15 degrees off that heading so you don't wrap the rode in the prop. Follow same as many times as required. When chain is up, run over the anchor to pull it out and haul it all up.
That's what I've been doing for over 25 years and it works.
Oh, and teach your wife to drive so YOU do ALL the anchor work. Why do you have her drop it? Sure, she should know how to do it, but having wives do any anchor work is not something I do - that's grunt work that's my responsibility. She can if she wants to, but rarely volunteers.:):):)
Oct 28, 2008
154
none none LA
Thanks, sounds like that will work. The one thing I have going for me is that we don't have much wind around here during the Summer.
My wife can handle the helm pretty well... when retrieving, she steers towards the anchor (with me giving hand signals, since you can't see the rode from the cockpit), and once I have the anchor up, I can leisurely sit at the bow getting things tidied up as she gets us out of the anchorage.
She really doesn't mind going up front to drop the anchor and pay out the rode (believe me, if she did mind, I would hear about it!), and it's not nearly as physical as pulling it up, so I don't feel bad about it. :)
--Michael
May 23, 2007
1,306
Catalina Capri 22 Albany, Oregon
I'm with Stu on not having the wife drop the anchor. The only time we have a problem is if the shallow water alarm goes off while we're anchoring. That freaks her out, especially in the dark! :eek:
Dec 2, 2003
1,637
Single Handed Anchoring in Crowded Anchorages
This is what I did on my previous boats with no electric windlass with controls on the steering console.
Anchoring:
Before reaching my chosen spot I find a less crowded place and pull out approximately the length of rode I will need and make it up on the cleat. Then I dangle the anchor over the bow and bring a bight of rode back into the cockpit with one turn round a winch, all the time keeping tension on the anchor.
I go to my chosen spot, release the rode from the winch and, after it has run out, just back up on it to set the anchor. Now, safely anchored, I go forward again and adjust the rode to the preferred length.
Weighing: I pull and wait and pull and wait as Stu recommends. A 31' boat should not be too heavy for this. When the rode is 'up and down', but before breaking the anchor out, I get a warp and put a rolling hitch on the rode and lead the end back to a cockpit winch. A quick wind of the winch usually gets the anchor out and I just pull all the rest in by hand. No windlass needed!
This way of getting under way (and anchoring) means I am always within reach of helm and engine controls and, if it starts to all go pear shaped I just drop the anchor to gain some time to think of what to do next.
Jun 6, 2006
6,990
The overall key to easy anchoring
Anchor in a snug harbor so you don't have wind/current to deal with. As the other posters commented on, having wind, waves or current to deal with greatly complicates the matter.
For the record once I'm over the anchor I can break it free with only minimal effort (danforth type anchor). Only had one time when I had to really fight with it but that was due to waves from traffic going by and it was fast in hard sand.
Oct 28, 2008
154
none none LA
Anchoring: Before reaching my chosen spot I find a less crowded place and pull out approximately the length of rode I will need and make it up on the cleat. Then I dangle the anchor over the bow and bring a bight of rode back into the cockpit with one turn round a winch, all the time keeping tension on the anchor.
This would be ideal, but how do you (or can you) do this with a chain/nylon rode? I would have chain running across the deck when dropping or weighing the anchor on the bow with the rode led back to the cockpit.
--Michael
Oct 28, 2008
154
none none LA
Our previous anchor (a claw) was pretty easy to break out... our current anchor (a Manson Supreme) is much harder! But on balance I guess that's a good thing... our boat sails around at anchor like crazy, and in windy conditions it's like a bucking bronco with a lasso around its neck.
--Michael
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
I haven't done this, but if you are really concerned about dealing with the chain you could use the chain overnight but the toss out your lunch hook (smaller anchor) with all nylon rode to secure you while you deal with pulling in an cleaning your main anchor/chain.
druid
Apr 22, 2009
837
Ontario 32 Pender Harbour
To anchor singlehanded: First, make sure the anchor is hanging overboard ready to be dropped Then, if there's wind, motor to just upwind and a bit to the left or right of where you want to drop the anchor (the boat will move sideways as it turns stern-to-wind). Go fwd and when it's time, drop the anchor and play out the rode till you're happy, then cleat it, go back to the cockpit kick her in reverse till the trees stop moving, and yer done!
To raise anchor (this replaces any exercise routine you might have to keep yourself in shape while cruising...): Engine on and in neutral, rudder centered. Pull on the rode till you get the boat moving nicely toward the anchor. Keep hauling till the line is vertical, then cleat off and let the boat's momentum pull then anchor free. Then haul in the remainder (including the heavy chain!) quickly, before the boat drifts down on the boat behind you. Get the anchor on deck and run back to drive the boat out of danger, but don't forget to go back forward and secure the anchor!
Now, if you're anchoring with a stern line in a crowded anchorage ("angle parking") you REALLY need a Plan...
druid
11,701
Here's a quick run down on anchoring technique. Even with extra crew on board I anchor & moor solo about 85-90% of the time.
Scope:
This is perhaps the single most important and over looked aspect of setting your ground tackle. Scope is the angle of attack, if you will, of the rode or anchor line in relation to the bottom. The longer the scope the more parallel to the bottom the rode will be and the less likely to yank the anchor out from a more vertical pull. A short or steep scope angle will most certainly yank the anchor out of the bottom and will not hold well when the wind picks up.
How do I know what my scope should be? Scope is easily calculated, but often calculated incorrectly. Scope is simply the max water depth, plus the distance of your bow chock to the water, plus any off set for your depth transducer. Huh? Ok, you pull into an anchorage at low tide and it has a current water depth of 10 feet. The area you are in has a ten-foot tidal range (Maine). So your max water depth will be 20 feet. You know your bow chock is 4 feet off the water and your depth transducer is 1 foot bellow the surface and not calibrated as such. So you simply add 20 feet of water depth, to 4 feet of bow height, to 1 foot of transducer depth for a total of 25 feet of scope basis.
To set your anchor you should be using a minimum of 5:1 scope but the preferred setting scope remains 7:1. So the 10 feet of water you read on your depth sounder was actually 11 because your transducer is a foot bellow the waters surface and when the tide is added to the bow height your 10 feet of water depth turned into 25.
So let’s pretend you think you set your anchor at a 5:1 scope, based on the 10 feet of water depth you saw on your depth gauge. Don't feel bad as many sailors and boaters do this. A 5:1 scope for 10 feet is simple it’s 5 X 10 = 50 feet of scope. Oh, oh the tide comes in and you have mis-calculated your scope! For the example from above you ACTUALLY have 25 feet from the bottom of the ocean to your bow not the ten feet you mistakenly calculated.
For this same 5:1 scope you would need 125 feet of rode not 50 feet. 50 feet of rode for a 25 foot scope basis is a VERY dangerous 2:1 scope or almost vertical at high tide. You are nowhere near a 5:1. Again, this is a VERY common mistake. Please calculate scope carefully and always add the bow height and max tide.
Rode: This is the second most overlooked aspect of anchoring. At a minimum you'll want to be using about 1.5 times the boat length of chain then a suitably sized, & highly elastic in nature rode. An bare minimum chain length is generally one times the boat length. Chain also prevents abrasion of the rode on underwater coral or rocks. An all chain rode is considered better but you will need to use a very elastic snubber to prevent shock loading of the chain.
Why is the chain important? The chain serves a few purposes: 1) It serves as a weight to help prevent the anchor line from snapping tight. It keeps a curve or caternary in it during mild to moderate winds helping to keep the angle of attack on the anchor correct. In high winds a sentinel or kellet may be needed to maintain caternary but even kellets stop working as the wind rises. 2) It prevents the nylon anchor line or rode from chafing on coral or rocks on the bottom. 3) It aids the anchor in proper setting by keeping the shank down so the flukes/fluke can penetrate when backing down. 4) It can lessen your swing circle in light to moderate winds.
Anchors: All anchors are not created equal and there is far too much to be written on this here.
Technique:
#1) Examine the anchorage: Make careful observations & based on weather predictions choose a spot that will be better protected from the prevailing winds. Also take note of how others are anchored and envision a 7:1 scope to mentally picture where their anchor might be on the bottom. DO NOT drop on top of someones anchor.
If everyone is bow and stern anchored you need to do the same or there will be “swinging” issues. If everyone is bow anchored only please, please, please do not bow and stern anchor. All boats must swing naturally, and in unison. If one boat is bow and stern anchored it will not swing with the crowd and there will be fiberglass on fiberglass contact. Anchoring contradictory to the crowd already there is considered rude and inconsiderate. Boats on permanent moorings are generally on a 2:1 scope and will swing around their bows, but will move very little compared to a boat on a 7:1 anchor scope so be careful and stay far enough away from anchoring near permanently moored boats.
In light air, boats with an all chain rode will not swing as far, or as fast, as those using a nylon/chain rode so take note of who has all chain to the deck. Choose your spot and visualize your boat swinging in unison with the others in a 360 pattern. If your spot has you hitting other boats during this 360 visualization exercise find a new one..
#2) Prepare & set: Once you’ve determined your “spot” calculate your scope as described above. For the best results use 7:1 for setting. 5:1 is an absolute bare minimum for setting and should ideally be avoided if you want consistent results. As you approach your “spot” shorten the dinghy painter so it will not foul the prop when backing down. Slide the gear shifter into neutral and gently glide past, and over, where you actually want the anchor to set. Once beyond your “spot” slip it into reverse and get the boat going in a straight line backwards but SLOWLY at perhaps .3 to .5 knots. Lock the wheel or tiller to keep her as straight as possible and walk carefully & slowly to the bow.
#3 Play out the rode:
As you begin to move backwards begin playing out the rode. Do not just drop a pile of chain or rode to the bottom, it will tangle the flukes. The rode must be played out while moving backwards, gently and methodically. As you begin to get to about a 4:1 (your rode should be marked in feet or meters) gently snub the anchor for a test bite. This will orient the anchor to a proper setting angle if it has not already happened. If you begin to feel resistance let off your snub and continue playing out line until you hit 7:1+ gently snubbing along the way every now and then. The greater the scope used in setting the better the result and better the odds of a first try set will be.
#4 Setting the Anchor:
With the boat at 7:1, with a good test bite on the hulls backwards momentum, let the weight of the boat and the remaining momentum partially set the anchor and come to a stop. Once the boat has finished stopping, and is back to a taught line, not jerked forward from nylon rode stretch, run the engine up to full cruise RPM, usually 80% of max rated throttle, and finish setting or burying the anchor. With small outboards you'll want to use full reverse as they tend to have lower reverse thrust when compared to inboard engines. If the anchor moves or drags you’ll need to start over. No small AUX sailboat engine should be able to budge a properly sized and set anchor for the given boat. If it does you need new ground tackle or need to re-set and try again.
For example 30 knots on a 36 foot sloop is about 900 pounds of force on the anchor. My 36 footer has a 44 h.p. diesel spinning a 16" prop and can only develop just over 500 pounds of reverse thrust at 80% of max throttle or nearly 50% less applied force to the anchor than 30 knots..
This last step, 80% of max throttle, is important and is one many overlook. Bottoms are often made of “layers” and the top silt / soft mud layer is easily penetrable and will hold fine in light conditions but not moderate or high winds. You want to dig the anchor into the next layer, the one that is much harder, and will hold even in high winds to be properly set.
I have spent a good deal of time diving on anchors and I can say that a good majority of the anchors out there are not properly set. With CQR’s this is usually represented by a partial sideways set meaning it is laying on its side with the tip partially buried. There was a perfect picture of a CQR doing this in the Sail Magazine anchor-testing article from a few years ago. If you are not back-winding the sails or using a large portion of your engines capacity your anchor is not really properly set checked.
#5 Shortening scope: Now that you set the anchor it is somewhat safe, depending on your choice of anchor, and chain/rode configuration, to shorten to a safer swinging scope for the anchorage you’re in. 4:1 is the generally accepted minimum for calm conditions or winds bellow 10 knots. 5:1 can usually be safe to around 14-15 and any wind speeds over that you will generally want more scope. Try and pick areas that will allow you to use the max allowable scope in case of a micro-burst or sudden storms or high winds. If you leave your self only enough room for 4:1 you’ll likely get precisely what you ordered, the “disaster plate special with a side order of heartburn and severe anxiety”.:doh:
Weighing Anchor:
If you don't have a windlass let the boat do the majority of the work for you.
1- Start motor
2- Put in gear and get moving in the direction of the anchor.
3- Quickly put in neutral and walk to bow
4- Begin collecting the rode as the boat glides towards the anchor (no pulling as the boat is doing that for you).
5- Once at a 1:1 scope, directly over the anchor, snub the rode and let the inertia of the boat yank the anchor out of the bottom.
6- If you did not have enough inertia go back to cockpit and give it a blast of gear and put her back in neutral this with a 1:1 will yank even the most solidly set anchors out..
7- Go back to bow and lift the anchor the 15-20 feet from the bottom and stow it.
8- If the anchor is muddy you can tow it at idle speed just below the surface to wash the mud from it then stow it.
9- If your chain is too long for the depth, for a 1:1 snub, get a short length of line and a chain hook to break it free at 1:1. Cleat it before you begin weighing anchor and you're good to go.
If solo an inflatable PFD with hand held VHF can be a good idea but truth be told I have been doing this for over 30 years and never worn one...:doh:I do usually have my VHF in my pocket though..
Hope this helps and that I did not forget anything…
Jun 30, 2004
446
Another idea about the chain! Use a kettle weight in lieu of chain. go to an all rope rode; be a mushroom anchor, big carabiner clip, and a secondary rode. After the anchor is deployed, snap the mushroom (kettle weight) on the rode and let it down.
May 25, 2004
958
Hunter 260 Pepin, WI
Under sail
I've used Stu's method single handed and under sail.
The extra steps:
Anchoring - let fly all sheets before turning into the wind. After the anchor is on the bottom, pull the main boom forward to back wind and assist the running out the rode and setting the anchor. Alternate sides to keep the boat directly down wind of the anchor.
Weighing - Have all sails ready to raise. Weigh anchor. Unfurl the jib and backwind to assist bringing the bow around. When you are free and clear of the anchorage, and have some speed up, round up into the wind and raise the main.
(My wife hates hearing the motor run :) )
druid
Apr 22, 2009
837
This is a bit of a hijack, but...
Does EVERYONE use the 5:1 to 7:1 scope recommended? Here on the Wet Coast, if you put out even 5:1, you'd hit every boat in the bay. Deep bay, for instance, is 35ft deep (not that deep actually!) and about 200 ft wide. Everyone sets anchor on one side of the bay and runs a stern line to the other, so they're sorta "angle-parked", about a boatlengh apart. But at 35ft, even 5:1 is 175ft, and if your boat is 30ft long and you're 30 ft from the shore, that puts the anchor 35ft into the woods. ;)
Patricia Bay is similar. Or, Plumper Cove is 60-80 ft deep, which would mean 350ft of rode - it's a bigger bay, but on a weekend, boats are about 200ft or less apart - you'd hit several as you swing around.
If I can get more than 3:1 I consider myself lucky. Fortunately, a Danforth with 30ft of heavy chain holds pretty well at even 2:1, and a CQR is good to about 2.5:1.
druid
Gary_H
Nov 5, 2007
469
Cal 2-25 Carolina Beach NC
For weighing perhaps you could run your road through a snatch block at the bow and bring the line back to the cockpit. Then as you motor forward slowly you can haul in the line until you reached the chain. you could then cleat your line go forward to manually pull the chain up the rest of the way. If its stuck pull it taught and secure it to a cleat and then drive forward slowing until it breaks free.
