Propeller residue...normal/not normal?
Jun 7, 2022
21
Goman Express Express 35 Gloucester
Hi, I'm a first time sailboat owner as of spring 2022 - so this fall was the first time I hauled the boat for winter storage. Here is a picture of my propeller. Is this white residue normal? Should I / can I remove it? Should I do anything to prevent this from happening next season?
- Looking at pictures from spring launch '22 it looks the same - but that doesn't mean the past owner was caring for it properly
- You'll note in the picture my zinc is nearly depleted, will replace that before launch in spring
- I'm in saltwater
Thanks.
dmax
Jul 29, 2018
1,102
O'Day 35 Buzzards Bay
It looks to me that the PO sprayed the prop and shaft with cold-galvanizing spray paint (zinc): Rust-Oleum Professional 20 oz. Flat Gray Cold Galvanizing Compound Spray 7585838 - The Home Depot
I use it on my prop and shaft and have no barnicle problems. If that's the case, you can lightly sand it and spray it again in the spring. Additionally, you should have two zinc anodes on your prop shat - you can see that the one is pretty eaten. Make sure the anodes have good electrical contact with the shaft (sand down to the metal).
Likes: Hollyberry
JamesG161
Feb 14, 2014
7,728
Hunter 430 Waveland, MS
It depends on the material of construction for the propeller.
Do you have that information?
Jim...
PS: It is not the white residue that is important, but the trailing edges of the propeller for corrosion.
4,076
Hunter 40.5 Warwick, RI
I have used the Rust-Oleum-Professional-20-oz-Flat-Gray-Cold-Galvanizing-Compound-Spray-7585838/100142963 for years and have observed the same whiteness at haul-out. I believe that it is exactly the same product as the Pettit barnacle spray product except it is $8 instead of $30 and the can is 25% larger. To me the trailing edges of the blades look to have pits in the spray paint vs a corrosion problem, but it is hard to tell from a photo. Once you sand it should be obvious.
And yes, given the condition of the zinc, I would place two of them on the shaft. If next year the zincs are in the same condition, I would investigate electrolysis leakage.
Likes: Walsh0575
Jun 7, 2022
21
@dmax thanks...interesting...I never thought it was intentionally sprayed as a protectant. Good to know...I'll re-coat it this spring after a light sanding. I'll grease it after that. Also, never thought of putting two zincs on the shaft. The PO was in a brackish marina and when I received the boat in the spring '22 the past year's zinc was in not too bad shape, but I replaced it anyway. I keep mine on a mooring in a harbor and was surprised by how much the new zinc corroded this season! I'll put two on this spring.
@JamesG161 The prop is a Max Prop 2 Classic which I believe is bronze?
7,302
Alden 50 Sarasota, Florida
adding multiple zincs serve only to magnify the “battery effect” of more anode and isn’t a solution to a corrosion problem. It merely prolongs it. You are better served finding out if the prop is as badly corroded as it appears in the picture and,if so, finding out the source(s) of electrolysis causing it.
Likes: ggrizzard
JamesG161
Feb 14, 2014
7,728
There is more to the Galvanic protection on his Max Prop 2 Classic
see the instructions from PYI, I linked him.
Jim...
7,302
Not true. Using two shaft anodes is very common and in fact provides twice the protection of a single anode. And considering the state of the anode in the pic, installing two next season would be a wise move.
Here we go again. Simple explanation:
when you have any anode, it provides an enhanced electrical path in the presence of any voltage potential. Adding more anode ”spreads out the anode circuit surface but changes nothing to affect the catholic side and can exacerbate the current flow. Whether doing anything common is irrelevant -lots of people simply don’t understand the theory. Don’t add to the myth.
Feb 26, 2011
1,437
Achilles SD-130 Alameda, CA
"The amount of protection a zinc anode provides depends on its surface area. The zinc surface area needed varies with the kind of metal being protected and with the chemical makeup of the water, but you can use 1% of the surface area of the protected metal as a starting point. Check the protected metal frequently. If it shows signs of corrosion despite the zinc, you need more surface area."
You seem to make the assumption that a single collar anode will provide enough protection, regardless of how much metal it's being asked to protect. That is simply not true.
7,302
no cherry picking internet excerpts needed. We’re talking about the OP’s 2 blade prop.
Likes: JamesG161
JamesG161
Feb 14, 2014
7,728
Per the science...
Mass Transfer Rate depends on ...
1) The Force [Galvanic Potential]
2) The Flux [Electrons flow/ Surface Area exposed]
The Analogy for Water flow
1) The Force [Pressure]
2) The Flux [gal/minute / pipe cross sectional Area]
Both @Don S/V ILLusion and @fstbttms are correct.
But a different view the elephant, so to speak.
Jim...
NYSail
Jan 6, 2006
3,132
Beneteau 423 Mt. Sinai, NY
Like was said, looks like paint…… my prop looks the same at haulout. If you have concerns about the prop, pull it off and send it to the manufacturer for an over haul. I hey will let you know what is what.
In regards to the zinc, do you know when it was last changed? Some boats that dont come out of the water don’t change them regularly….. it may be 2+ years old and in that case the wear looks fine. Though on my boats I always have used 2 (1 shaft collar and one prop) as I am in a marina and am always plugged in during week when we are home.
JamesG161
Feb 14, 2014
7,728
If all would read the PDF file for his Max Prop 2 Classic
My Post #9
There is a Zinc built into that propeller. That MUST be changed in addition to the Shaft Zinc !!!
Jim...
PS: 2 Degreed Chemical Engineer with SBO moderator powers too. Keep the discussion to help @Walsh0575 please.
Feb 26, 2011
1,437
My Post #9
Older model Max Prop 2-blade Classics do not have an anode. This is the prop the OP has.
