Specs say 52.5 w/o antenna. Do you recall what the boards read when you went thru?We went under both bridges a couple of weeks ago at close to high tide. Our mast is 52' according to specs (haven't measured it) plus about 2.5' for the antenna and cleared with out touching.
How high is your mast?
You will be fine going through at mid tide or lower. We're about the same height. The whip antenna is flexible, no harm if it touches.Specs say 52.5 w/o antenna. Do you recall what the boards read when you went thru?
Thanks for your reply
Also known as a bridge feeler gauge alarm...whip antenna is flexible
Why? The bridge hasn't moved in the 2 weeks since I went through it with a 52 foot mast.You might want to call Utches or Canyon Club for current information
When the bridges crossing the ICW were built some of the field engineering was off a little and the actual bridge height is not as it was supposed to be. Also, the height boards have been known to be off or so obscured with marine growth the height is not readable.Did you mean current or current?Just wondering if you meant current as in today or current as in how fast the water is flowing?
I'm not really understanding why the current bridge height would differ from the information on the charts. It's not like it has been re-constructed recently, has it? Sea level hasn't changed all that drastically has it?![]()
thank you that is what I was looking forWhen the bridges crossing the ICW were built some of the field engineering was off a little and the actual bridge height is not as it was supposed to be. Also, the height boards have been known to be off or so obscured with marine growth the height is not readable.
We went western bridge at 3:15 on June 10, 2022 and the eastern bridge a half hour later. On June 10 high tide was at 5:57 PM. So we know that the bridge clearance is at least 52' plus the height of a Metz whip antenna at mid tide. I would be anxious about trying to clear the bridges at high tide on a King Tide, but at mid tide or lower, not a problem.
Here's a link to my track if anyone feels the need to verify it.
[/QUOT
So John, are you saying I'm not trustworthy? Inquiring minds want to know.It is great to get others observations/experiences. Trust your own calculations when it comes to navigation.
Trust but Verify.
So 52' plus antennae would seem to indicate that the chart listing at 55' vertical clearance seems to be a good reference. Saying that the field engineering was off is not an indication that the chart reference is inaccurate. I wonder what Navionics uses for their reference (aside from the mean high tide reference). If the "field engineering" is not accurate that may simply mean that the as-built doesn't exactly match the design (a common occurrence) but the as-built reference should be accurate (a more serious matter). Does Navionics use the as-built or do they have their own independent reference? (Surely they don't rely on the design calculation).When the bridges crossing the ICW were built some of the field engineering was off a little and the actual bridge height is not as it was supposed to be. Also, the height boards have been known to be off or so obscured with marine growth the height is not readable.
