Hello,
I have a weird issue which has me and the mechanic and several people I have asked stumped.
I have a 1998 Hunter 310, it has the original Yanmar 2GM20F 18hp engine in it. 2400hrs on engine. I have a single cranking battery for starting and 2 6 volt batteries for the house.
Anchor is wired to run off the house bank.
Issue is whenever I go to use the anchor, if the engine is only idling the engine stalls. Normal idle on tac is about 1000RPM, set by mechanic. I can rev engine up and use anchor, but slow down to change gear it stalls, so slowly down from a fast reverse or forward and engine stalls if still letting out or raising.
When engine stalls, it starts up right away, no hesitation, no smoking, runs perfect heat at full revs for long periods. Mechanic says engine is running great and I kinda agree.
I did some voltage tests with smart meter.
engine running - batteries at 14.2 v. When I raise anchor (rated to draw 80amps)
1600rpm, 20amp draw from batteries, alternator supplies 55amps
1200rpm 35-40 amp draw from batteries
1000rpm 55 - 80 amp draw from batteries. Engine stalls.
We just redid governer, all springs and such, cleaned air filter. Have redone fuel filters twice.
Anchor raises and lowers fine with motor off.
Ideas ????????
Ideas ????????
