I have a short somewhere in my cabin lights that is blowing a 20 amp thermal breaker, and I want advice in finding it. There have been no recent changes to the cabin electrical, so it's not a simple matter of "Undo what you just put in". When the breaker started blowing, my first try was to simply replace the 20-year old breaker - no luck.
My next try was to break out the amp meter (this is getting to be actual work!), and validated that with all cabin lights/fans/12v plugs off, it starts with 5 amps and ramps up to 37 amps within a few seconds, before the circuit breaker trips. Now my problem - I know there is a short somewhere between the single line to the panel and the switch to some device, but how do I find it quickly? The single power line disappears into a cable wrap and then behind a panel. I suppose there is a terminal block somewhere to divide it up. Any ideas for the quickest, highest-probability-first search?
I know that this has probably been covered before, so could someone just point me to the right thread?
