Hi guys! Mrs. PP here again.
I’ve been reading the online Hunter 38 owner’s manual PDF which gave me much useful information but also puzzled me quite a bit as some of the details were very vague and/or didn’t explain any of the following. After searching throughout the boat, I was curious as to how the discharge systems actually work.
The macerator is something I think we would rarely use (when 3 miles out per legal requirements), but in the event we were on a long cruise and needed to, it would be nice to understand how to properly discharge the black water tank. I noticed there is a macerator pump with a valve, a thru hull discharge, and two macerator switches on the panel. I’m assuming when all of these are open and switches on, it will discharge out the thru hull. Is there a particular order in which this must be done to ensure there is no back flow or other problems?
Also, when checking out the thru hulls, I see there is a galley drain discharge and vanity drain discharge. Both of which are currently open. Are these meant to be left open when docked, closed when not? When using the sinks, do these drain out of the boat or are they draining into the black water tank? I always assumed the latter, however, now I’m not certain what their intended use is, how to properly operate them, and when they should be open/closed.
Can anyone please give further clarification on the proper operating of these discharge valves? @quadrille38 You likely have the exact set up.
