Interesting comments … Thanks all! Dave, you are right, I don't really look at it nearly as often as I read the instrument. The issue is that I have had it this way for over 10 or 11 years. Honestly, I wouldn't know the difference until I switch it to pointing forward. Obviously, I have calibrated the instrument for the mounting direction.
It certainly does look flatter (lower relative to the mast head) in that photo. When I look at the mounting angle of the sensor (in my hand before it is mounted), though, I wonder how it could be affected by a vortex. My suspicion is that it is. It often seems that the apparent wind speed is less than it should be when I am sailing upwind. I have no basis for comparison, but there are times when I'm sailing upwind in gusts that would seem to be higher velocity than indicated by the apparent wind speed reading (based on readings that I can see when anchored). This year will be my first opportunity to read true wind, so I'll perhaps have a better sense of it. However, I have no idea how to really tell if it is accurate or not.
I do sense that the wind direction is often more erratic than I would guess. For years, sailing on Lake Hopatcong, I figured that the erratic direction was mainly due to wind shifts on the lake. However, now with winds in an open bay, I still sense that the direction can be more erratic than I would expect. Perhaps it (the erratic readings) is impacted a lot by angle of heel? Perhaps moreso than it would if it was mounted forward.
There's no cause for me to brag about pointing angles on the apparent wind angle.
One look at the GPS track is enough to tell me how low my pointing angles really are!
I can't say that I have ever seen another boat with it mounted backwards, like I did mine. The installation manual, when I read it over a decade ago, seemed to indicate that it was a matter of preference and not that significant an issue. The masthead had an old instrument already mounted when I bought the boat, which I took off because it was not working. It was simply easier to mount the new one (10 or 11 years ago) in the original location with the sensor pointed backwards so the bar wouldn't interfere with the anchor light. I'm sure I could find a way to re-configure it. When I bought the Triton sensor last year, it fit my (Simrad) mount so I didn't bother to change the direction.
