I have made up a brace like used on the gudgeon they sell today.
I have a TIG welder and can put in steel panels almost good enough you would have a hard time finding the seam in bare metal. I have played around with car restoration.
So I got some SS and started looking up on the web what I needed to know. One thing you have to do is passivate the weld area. When you weld you bring the iron to the surface and it can rust. It does not hurt things, but it stains. There are all sorts of acid dips that corrects this, but they require nasty chemicals that are not easy to get. So I am trying some Goof Off Rust Stain Remover which is a weaker version. Put some electricity into the mix and it is supposed to do the job.
Here is a pict of the test weld I did. What you do not see is the heat discoloration. This is after passivation. It seems to have worked. Not sure yet about the black stuff, need to look it up.
