Parts I can't buy
Oct 24, 2010
2,405
Hunter 30 Everett, WA
I broke a small clamp that holds the autopilot ring on the wheel. I didn't find a ready supply of parts. I ended up cutting one out of plastic and painting it black.
It works fine, but what does everyone else do when a minor part isn't available? It seems like I'm frequently unable to buy what I need.
Is it just me?
Ken.
2,366
have you tried the plastic saddles for conduits/water pipes?
capta
Jun 4, 2009
5,008
Very few ancillary parts for marine items are specifically built for just that purpose, the market just isn't large enough. Therefore, many parts can be sourced from suppliers of other industries.
Those clips might also be used to attach items to bicycle handle bars, for instance.
Beneteau 323 Annapolis MD
They look like half of a rail clamp, made for various mountings.
Oct 24, 2010
2,405
If you zoom in you can see "Autohelm" molded into the parts in raised letters.
It isn't just this part however. I'll always fafricating something. Another example: I just built a locking cabinet for a Yamaha TF3 mixer. How else do you keep little fingers out of there in a church. It seems like I'm always building something I can't buy. For several reasons I also had to build of set of offset hinges for the above cabinet.
It just seems like the simple stuff just isn't available.
Ken
Sounds like this would be an excellent job for a 3D printer.:poke:
If you don't have one an excellent reason to get one.:biggrin:
Likes: Allan12210
Oct 24, 2010
2,405
I have one now, and really, $29 us after shipping for that?
I guess I'm glad I made my own.
The issue still isn't just that clamp. It's just that I always seem to need something that isn't available.
Ken
20
Beneteau Oceanis 445 Salt Spring Island on my dock
I know this is an old thread, but our company, www.i3DGear.com 3D prints all the spare parts for all the old Autohelm and Raymarine wheel pilot systems. We do this so people don't have to throw away their entire autopilot system just because they can no longer get a small lever, gear, roller or other parts. Helps the environment a lot and saves you having to make new holes in your helm to accommodate a completely new autopilot system.
May 20, 2016
3,015
I agree with @jssailem 4D printing or cnc routing will make lots of things you can’t buy. Manylibraries have 3D printers.
Les
Sep 12, 2018
20
A note about 3D printing. Much like how having PowerPoint does not make one a graphic designer, 3D printing is the same. Making strong, properly designed parts with a 3D printer is quite a science. Printing with the correct plastics, with the optimum print parameters, selecting the best orientation for printing, etc are all things that are highly technical and take years to master. Simply downloading a file from a website and trying to print it yourself might not result in an optimal outcome. (eg. buying a sailboat does not make one a Vendee Globe racer).
I see parts designed by amateur 3D printer enthusiasts all the time that, while good intentioned, are full of design flaws and weaknesses. One of the most common is people 'exactly' replicating parts that were previously injection moulded. Injection moulding has so many limitations and constraints that many of the 'features' you see in injection moulded parts are not functional elements, but are there because of the limitations of injection moulding and only contribute to the breakage of the part. 3D printing has its own unique set of constraints and limitations that are entirely different from injection moulding. Elements intended to make injection moulded parts strong (like ribbing and nominal wall thickness) actually work the opposite in 3D printing and make the part weaker.
May 20, 2016
3,015
An engineering degree in material sciences helps :dancing::dancing:
Mine is in ceramics but much is applicable
Les
Aug 1, 2011
3,972
A ceramic dish makes a much better Shepard’s pie. :)
Michael That would get both of us in serious trouble.
Sep 12, 2018
20
Okay, this has totally degraded now...... :badbad:
End of thread I'd suggest!
Likes: Rick D
