I noticed a crack in the compression post today. My guess is that it is not new, but increasing. I had noticed the lid to the stove area not fitting as well the last season (or two?) and the sink has some old caulk that is definitely above the current level of the sink and has been for quite awhile. The side panel under the left side of the sink has pulled loose and the screws are probably 1/4" off where the holes were.
Where the mast sits, there are some hairline cracks around the base, but there does not seem to be any obvious compression to this or at the base of the post on the floor. The angled tension bar that runs from the mast to the compression post seems to be pushing the compression post at an angle. Did the post fail at the point of the screw and the tension bar is causing this over time , or is there a deeper reason?
How serious is this, can it wait until fall for a fix? Is there a temporary fix in the meantime? Is there a way to re-straighten the compression post and reinforce it? Would letting some of the tension off the rigging help - maybe it is too tight?
