No. Do you have an accumulator tank? The pump should pressurize this tank and it should remain full until a faucet is opened. If there is a small leak, the tank will call the pump to pump more water in to the tank. That causes the cycling. If this is happening, there is probably a small leak some where. It could be a leaking faucet, a bad hose connection, or a leak in the accumulator tank.Is it normal for the fresh water pump to cycle periodically? If so, how often is normal?
What is an accumulator tank?No. Do you have an accumulator tank? The pump should pressurize this tank and it should remain full until a faucet is opened. If there is a small leak, the tank will call the pump to pump more water in to the tank. That causes the cycling. If this is happening, there is probably a small leak some where. It could be a leaking faucet, a bad hose connection, or a leak in the accumulator tank.
Thermal expansion/contraction is another potential cause of the pump cycling on. If your water heater is up to temperature (typically 140F or hotter) and that heat is removed (engine shut down or power turned off to water heater or hydronic furnace turn off) the water in the tank will contract reducing system pressure to a point where the fresh water pump may cycle on.Is it normal for the fresh water pump to cycle periodically? If so, how often is normal?
All of the faucets have strainers or aerator screens. I am guessing that your supply pump has a suction strainer too.So some weird stuff going on
Mine too!Is it normal for the fresh water pump to cycle periodically
Some household faucets will limit the hot water flow if there is no cold water pressure as an anti-scald feature. I don't know if any marine faucets do that but it may be worth considering.When I replaced the Cullagan water filter (charcoal type) that services the cold water into the sink the pressure at the sink dropped to a dribble. Both hot and cold seem to dribble so I believe it may be the faucet.
