Hi Friends,
before I call in the engineers I have a small problem I hoped you guys may be able to help with?
I clean and replace my paddlewheel for water speed every few weeks, normally without problem. With the power on and the transducer in my hands, a flick of the wheel registers speed on the helm display nicely. However, as soon as its inverted and thru the hull nada, regardless of what the SOG is. Everything else on the display at the helm seems correct.
With the blank in Ive been under the boat and whilst a little slimy there is no growth, I even gave the whole area around the exit a rub with an abrasive pad. Ive tried jiggling the transducer, taking it out and back in, all to no avail.
When I pull out the blank water ingress seems no different to how its been in the past,
I had considered poking a brush or something through the hull just to make sure nothing was in the tube, but surely the blank would do the same job?
Any ideas would be much appreciated.
