Solar Panel Cable Clamps for Bimini Tubes?
jviss
Feb 5, 2004
6,748
Tartan 3800 20 Westport, MA
Greetings,
I am installing two solar panels on my new bimini. I am using paralleling "Y" connectors up top, so I'll have only two wires coming down. I need to secure them to the bimini bow tubing, and lead them down to a cable entry plate I will isntall on the cockpit coaming.
The wires are "#10 AWG 1000 volt PV Wire with Tough XLPE insulation." It's fairly thick insulation.
Can anyone please recommend a neat way to support the cable along the bimini tubing? I'd like to avoid just zip-tying it.
Thanks,
jv
Sep 4, 2007
766
Hunter 33.5 Elbow, Saskatchwen, Can.
How about those wiring looms? Like they use on trailers and around wiring bundles. I don't know if they come in any other colour than black. They would have to be uv protected.
jviss
Feb 5, 2004
6,748
Thanks for the reply. I'm not quite sure to what you refer. Can you please be more specific?
jviss
Feb 5, 2004
6,748
Oh, gotcha. No thanks, I was hoping to find some kind of clamp that's not too un-aesthetic, to clamp the pair of wires at intervals along the bimini tube. I was thinking, perhaps I'll just pair-up nylon cable clamps and put a screw into the tube to secure them.
Feb 20, 2011
7,995
o_O It's your boat.
Personally, besides running the wires internally, zip-ties are the way to go.
Likes: SailormanDan
Jan 24, 2009
450
1981 Cherubini Hunter 27 Shipwright Harbor Marina, MD
This would require drilling the tubes and feeding the wires, but would be the most aesthetically pleasing.
But for me, :plus: for neatly zip tying it.
I've had a wire loom over the wires coming from the solar panels mounted on the seahood for years now and it's protected them nicely without being tied to anything until they snake down along the companionway grab rails, where I used velcro ties in case I wanted to remove the whole set up, definitely a case of the temporary becoming permanent.
jviss
Feb 5, 2004
6,748
I've used zip-ties for the GPS cable coming down the bimini tube, and it never really worked well. The cable would wrap around, the zip-ties break, and so on. The tube is way too small to run the solar cables inside.
jviss
Feb 5, 2004
6,748
Yea, I will looking into drilling and feeding, but I think the wire is too big and the tubes too small. They are 7/8" stainless steel tubes, and the wires' outside diameter is over 1/4" (.288" nominal). In addition, the cables don't stand tight bend radii, so it would likely have to be a big, long oval whole in the tube, perhaps compromising the structural integrity.
Mar 26, 2011
3,420
Corsair F-24 MK I Deale, MD
There is no reason to run PV wire if it will be under the bimini. If there is a short bit exposed, use wire loom there.
Sumner
Jan 31, 2009
5,254
jviss
Feb 5, 2004
6,748
Thanks! That's exactly what I had thought, and I went to Home Depot's web sit to look. Only diff is the SailRite jig has a drill guide bushing, which I think I could add to the Home Depot part.
jviss
Feb 5, 2004
6,748
Thanks! That looks like a very robust installation.
It gave me an idea, that maybe I would just install a redundant, stainless steel tube, parallel to the bimini bow, that ends inside the bimini pocket at the top, where the wires will enter, and then exit them near the cockpit and into the cable entry plate that will be mounted on the cockpit coaming.
