Thanks I was wondering if blowing it out was an option but didn't want to ask a dumb question!I don't have saltwater experience so you'll have to ask someone else about saltwater. I leave mine in a freshwater slip and drain the ballast every time I pull the boat out. Before discovering why Clorox is important the ballast water got so nasty I could hardly be on the boat. Draining the water and adding Clorox did the trick. I've seen threads where folks talk about using an aquarium-type pump in the air vent to blow the ballast out through the bottom. That's another thing I have no experience with. But honestly, pulling the boat out on the trailer is pretty easy. I pull mine 4 or 5 times a year for cleaning. The mast stays up then I put it right back in. I hope this helps.
My main concern with the water ballast in salt water is algae or barnacle growth like you see on the bottom of boats.Lots of water ballast stay in salt water all the time with no apparent damage to the ballast tank. Not sure what the concern would be unless it would be blisters but have never heard of that.
One of our boats is a MacGregor 26S (swing center board/displacement hull) and the last time out I tried 'blowing the ballast tank' with an air mattress 12 volt pump and it blew the water out the bottom of the boat in about 15 minutes or less. The ramp was very shallow where we were and I didn't want to back in as far to get the boat on the trailer. Without the ballast the boat floated higher so the trailer didn't have to be in as far.
Sure a water ballast boat is a little more tender than most keel boats but will still stiffen up at some point.
At about 18-20 degrees the Mac just digs in and is solid and I'd imagine other water ballast boats are the same. You aren't going to want to sail maybe any of these smaller boats in winds over 20 kts, but people do and the boat will.
The Mac is simple easy (fast) to rig and easier than about anything to launch as shown above without a ramp. The cockpit is large and the tiller doesn't come that far forward. I much rather have it than the space a wheel would take up.
The rear berth is larger than the berth on our 37' Endeavour and I'll bet larger that about any boat that has been mentioned. Still I don't think I'd recommend it to you considering what you seem to be looking for, but for someone else that is reading this thread take a look at a displacement water ballast boat like the MacGregor 26S or others. They have a lot to offer,
Sumner
1300 miles to The Bahamas and Back in the Mac...
Endeavour 37 Mods...
MacGregor 26-S Mods...
Mac Trips to Utah, Idaho, Wyoming, Canada, Florida, Bahamas
I could be way off base but I consider the effort involved to be similar to setting up a camper for a weekend getaway which usually takes 30 minutes to an hour which I am alright with. In my mind I see me moving it around to different areas from time to time on the trailer to try out new scenery. I have a pretty fast airplane so trips even as far away as Florida to get on the boat isn't a big deal. Sailing it all the way to Florida (for example) would take more time than I could take off work.OK, another consideration from an other ME. Many years ago when I was looking for my first sailboat I considered a trailerable. Then I realized that the time involved to launch AND rig the mast and sails would result in not using the boat as often - evening sails -
Unless only launching in spring and out in fall, keeping on a mooring or slip. Of course only if you live near the water.
Thank you for the very insightful post. I guess my take is that even if I was interested in a larger boat that couldn't be trailered it would still have to be a shallow draft boat for navigating the shallow waters around the NC coast. That being said I don't think there will be a huge performance difference in one of those versus the boats I have mentioned but then again, what do I know that's why I am posting here. Cost rise exponentially with larger boats too with hull cleanings, rigging, slip fees, more systems to be maintained. If I decide to upgrade in a few years it will only take a few months of paying for a slip on a boat I am trying to sell to offset any looses I may encounter of a trailer sailor.I love trailer boats because they are able to be moved large distances in a short time to allow access to distant sailing venues and while being moved the boat serves as an RV on the road. We keep a boat on a trailer just to take trips to different bodies of water around the country. Some mistake the function of a trailer boat as a boat that can be stored on a trailer and will not require the expense of a wet slip. These folks will soon find out that trailering and rigging the boat is a time consuming endeavor that gets old rather quick. They will soon find themselves making excuses why not to go out and the boat will get used less and less. Boat ownership is just part of the boating experience and having a boat in a wet slip just opens up the possibilities of going to the boat and getting on the water in a matter of minutes; how many times I have gone to check up on the boat and ended up taking an evening sail for an hour or so. Having the boat on a slip also buys you a membership on the slip neighbors boating club and I find it very enjoyable to just sit around in the boat exchanging stories with the neighbors. A boat sitting on a trailer in a parking lot or at home does not offer much in the boating experience sense. Trailer boats are based on a design compromise to make them easy trailer with a small truck or family vehicle and to make them easy to launch and retrieve from the average public ramps. ease of rigging and stepping and unstopping the mast is another design consideration. These compromises result in a boat limited in size, displacement and sailing capabilities. A price well worth paying for the ability to trailer but if the personal goals are to have a boat on a slip the trailerable might not be the right fit. I don't believe in purchasing boats intended for a short temporary goal as the time and effort and likely monetary loss upon the resale is bad business. I always say learn to sail the boat that you ultimately envision yourself and buy the boat that will best meet all your needs for the foreseeable future. For the same price of a good size trailerable you can get a fixed keel 28' to 30' boat that will be more comfortable, offer better performance and take you out into coastal waters for a more complete cruising experience. Of course there will be slip fees to be paid year around but that is the price for the full enjoyment of the sailing experience. Years ago a very good friend lent me a boat for 2-3 years when he was out of the country and I paid the slip and registration fees and the insurance. at the end of the loan I felt like I had purchased a boat and sold it with no loss and was better for the enjoyment I had gotten out of it. It was a good deal for both and it shows that boat ownership is overrated and what you really enjoy and should be willing to pay for is the experience.
You are missing my point. I can understand if it is a question of budget or time constraints but to correlate the cost of slip fees with the price of a boat is not the best outlook. On the average, boats in slips get used more frequently than those sitting on trailers. It can be said that it is a better utilization of the investment in the purchase of the boat. I have not met anyone that enjoys the drudgery of repeatedly trailering and rigging a sailboat just to be able to go sailing. That is not the best part of the boating experience. I agree that slip fees do not purchase anything tangible but it is the cost associated with enjoying boating to its fullest. In your case where you reside a little ways away from the coast having a boat on a slip could be regarded as the rent you pay for having a beach cottage. You could drive to the boat on a Friday night and wake up early Saturday morning in the water. All I suggest is that you do not discard the idea until you have tried it. I'm not trying to convince anyone that my way is best but just to open up the eyes to those that may not have experienced keeping a boat in the water. Boats we buy and sell, we cannot take them with us and all we get is the fun and enjoyment of their use so why not use them to their fullest.If I decide to upgrade in a few years it will only take a few months of paying for a slip on a boat I am trying to sell to offset any looses I may encounter of a trailer sailor.
Did they make a tall rig version of the 250?? Cool if so!Sumner: I don't dislike water ballast boats, it's that I prefer heavy keel/tall mast for myself to sail.
kloudie1: You got it! 24 to 26' trailerables are definitely not a good idea for a weekender type boat. Maybe if you are 22................. Chief
