Boarding a center cockpit boat
Feb 24, 2009
89
Beneteau 36cc Fort Myers
We have a new to us 36 Beneteau Center cockpit. It came with a set of dock stairs For boarding. If we are cruising is there a better way to board this boat without taking those stairs with us ? Any help or ideas sincerely appreciated
May 12, 2004
1,505
How about a small folding step stool that you can lash to the deck or stow below when you are underway?
7,596
Alden 50 Sarasota, Florida
Rope ladders, some with wood steps, which hang from the stantions or toenail are commercially available or can easily be made.
capta
Jun 4, 2009
5,006
Do you intend to go from marina to marina or board your boat from a dinghy?
If I am boarding from a dock I like to have something to grab on the boat - with or without steps. That's why I typically board any boat from a dock by grabbing a shroud, putting a foot on the rail and hoisting myself up. So even if there are steps I would want them at the shrouds not at the cockpit. Many boats drop their lifelines in the cockpit area for easier boarding. But that leaves little to grab. If some Tuna steps off the floating dock as you step onboard there's not much you can do except hopefully grab a piece of boom, if you're lucky.
For away situations a milk crate works pretty well and doubles as storage away from the dock.
Likes: capta
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
Whew! I thought the OP was asking about the best way to put holes in a center cockpit. I was like "Why would you want to do that?" and secondarily "Probably most normal methods involving a drill would work if that's what you really wanted to do!" :D:D:D:D
capta
Jun 4, 2009
5,006
We are searching for a side accommodation ladder, like the ships use. A far easier way to board a high freeboard boat,especially for us older folks and those with big dogs. They work at the dock and at anchor.
Likes: NotCook
Jul 27, 2011
5,144
Bavaria 38E Alamitos Bay
We have one like this for use at the dock when traveling. Folds flat so is easy to stow. Be sure to tie it to the boat or pick it up when leaving the boat. We've had to chase ours after the wind blew it into the water. Also, keep it out of the sun as much as possible. West Marine < $20.
1,096
CS 30 Toronto
I hate it when someone screw a ladder onto the slip. Huge tripping hazzard when coming in especially for visitors.
As for portable ladders, someone has to get off the boat before you can place the ladder on the slip. I prefer the hanging design.
I made one out of marine plywood.
capta
Jun 4, 2009
5,006
Actually, I can get them made down here in either stainless w/wooden steps or alloy for about us$3500 IF I can make an order for 10 or more.
The ones from Marquipt start at around us$7500 plus extras. Were I to hit the lotto, there are a few companies that make some real beauties in carbon fibre that are strong and light as a feather (15k+). Until then even $3500 would be expensive though possible, but it would probably add a fair few years to my sailing adventures. Stepping out of the dink onto a nice platform and walking up a few stairs just seems so civilized, doesn't it?
Feb 20, 2011
8,062
Mmmmmm, carbon fiber.
I suspect that the 10-unit deal would require they all be the same dimensions?
Beneteau 323 Annapolis MD
I got a postcard from Beneteau a few months ago with a new product I guess they endorse .
capta
Jun 4, 2009
5,006
Preliminary discussions with several metal fabricators down here were for a top and bottom platform, 5 stairs (I think we could also do 4), the bracket to keep the upper platform level, securing points for the rigging on the lower platform, stanchion sockets (no stanchions) and cleats for the dink. The actual attachments for the upper platform to the boat (2 brackets) would not be included as each boat would have to do that as needed. It would fold up and lay flat against the lifelines as in the pic of the S/S one below.
Of course, if I had them produced down here (under my supervision) there would be shipping, but that's really of little consequence. I had a 77 gallon barrel (about 200#) sent to St. Lucia as LCL cargo and it was $167.00 for the surface freight.
Oct 24, 2010
2,405
Hunter 30 Everett, WA
We use a white one but tie a lanyard on to keep from losing it in the drink. I also built a single step hanging from the toe rail. When the dock is low, we use both. When coming in the Admiral stands outside the lifelines on the toe rail step and just steps off onto the dock lines in hand. (Except at Roche Harbor where the dock is almost level with the toe rail.)
Ken
