I like Dave's basic idea, here's maybe a better more proven approach.
Keep in mind I think this is a good trick for a REALLY loaded up sections, like babystays or Code-0 halyards. But for a simple spinnaker for a H26 I think a good 4-point halyard restrainer will keep you going.
And in any case use Tef-Gel to protect against dissimilar metal corrosion. Much better and easier then rubber washers.
Instead of a common round tube which will almost never lay perfectly against the inside wall of the mast, call your mast supplier and get a foot-long section of existing extrusion. US-Spars will do this for sure for a few bucks. Cut the back 1/3 of it off, and lightly sand the mast and the inside of the section. Slather it up with 5300 and snap in place. SS rivets in the corners. When the devil glue sets God could not take it apart.
Putting it on the outside solves the nasty problem of reaching down beyond a few inches. No way you get to the hounds on a H26.
