as for the claims of the echo charger controlling the charge of the slave battery, without a few more wires being needed, it isnt possible. and is unnecessary for the distances we are using. if the banks were a boat length apart, it would make a difference.
The Echo Charger works perfectly fine and is specifically intended for keeping small AUX or starting batteries topped up. There is no need for any additional wires.
In many instances an Echo Charger wind's up being less costly than installing an ACR due to the larger wiring and over current protection needed for the ACR.. Remember a 3% voltage drop at 14.4V results in just 14V at the battery... With the Echo's limit of 15A this means AUX or Start battery charging can be done with significantly smaller wiring no matter how big the alternator, charger, inverter charger etc...
when its full of charge and cant take anymore, the current flow will essentially "backup", and if the other batteries are also full, the charger will sense it and shut off....
Charger's don't shut off. They simply pulse the power supply on and off to maintain a voltage. Some do a MUCH better job than others at low mA level current delivery. Some good ones are stable down to 0.1A or lower while some others can't do much below 2A without pulsing the power supply......
ACR's and Echo or Duo Chargers only shut off/un-combine when the system voltage drops below a pre-set point. Most are in or around 13.0V for automatic turn on... Echo's & Duo's are voltage followers. They follow the voltage of the house bank minus a tad bit of voltage drop. neither will go into float on its own they only float when the house bank floats. ACR's are nothing more than an automatic BOTH device which turns on or off based on voltage. They are technically called VSR's or voltage sensitive relays.. With VSR's batteries charge in parallel at the same voltage for both banks.
if during several starts, you lower the charge in your start battery enough, some of charge from the house bank, assuming its still full, can spill over thru the ACR to replenish the loss from the start batt... this is a very slow transfer process, so the house bank cant be used to "start" the engine. (you will have to use the "1-2-both" switch for that)
if this drops the charge enough in the house bank, the charger will kick on and bring them all equally up to snuff again.
Again teh ACR combines based on voltage. If the house bank comes up to 13.0V then the banks are paralleled. Only a drop in voltage can make the ACR un-combine. The "transfer process" with a VSR/ACR is as fast as the batteries can accept the current at XX% SOC and XX.XX volts or as much as the system can deliver.. The only limit to an ACR is what the relay itself can handle. If you have a 120A rated model then you don't want a 160A alternator....
if you deeply discharge the house bank and the charger is running full tilt trying to get them back up to where they need to be, the high current/voltage is NOT running thru the downstream battery to get to the house bank. so there is no problem.
This is true! IF the ACR is PROPERLY wired for a deep cycled house bank. The proper wiring for any ACR, on a cycling bank, is to run ALL charge sources direct to the larger house bank. This prevents relay cycling.
the ACR works in mysterious ways to keep the separate banks charged and protected
There is absolutely nothing mysterious about the ACR. It is nothing more than an automated BOTH feature....
Voltage Above Turn On = Batteries Paralleled/Combined
Voltage Below Turn On = Batteries Isolated/Not Combined
VSR/ACR's, Echo Chargers & Duo Chargers are all excellent products and what you are doing or trying to accomplish with them dictates which product you choose for the job...
I thought an ACR could connect a large battery bank (400 Ahr's in my case) that was down maybe 40% on to a fully charged emergency battery of only 100 AHrs in size.
An ACR can connect banks of any size you need to. It is no different than you flipping the BOTH switch to BOTH only it does so automatically based on system voltages.[/quote]
I don't know when an ACR combines the house and emergency banks but if it as soon as the alternator turns on I think there maybe a lot of current flowing between the small fully charged emergency start battery and the half charged house bank. I did not think this was a good idea.
There is sooo much misinformation out there about ACR's that it is really sad.. If the house bank has come up to 13.0V then it will combine. At that point the batteries will take what ever current they need or can accept, off the system bus, at XX.XX volts and XX% SOC. Very simple devices...
If the ACR is smart enough to wait until both banks are equal then it would not be an issue.
Again there is no need to wait until the banks are
equal because they will take what they need.... The start battery will need next to nothing so it will take next to nothing off the system. The house bank has the greatest need so it will take almost all the current... Once battery voltage reaches parity (parallel), which happens quickly, the batteries simply take what they need in current..
I have never owned an ACR so it may not be a problem, it might be something to check into.
Bob
Between all the manufactures of VSR's there are literally millions of them in service world wide.. No issues other than installer error.... If you already have an Echo charger and it works for what you do then keep it.... If you are starting from scratch then weigh the options and true
installed cost......
Alternatively, the "echo charger" claims to control charging of the slave battery and shut of when it's charged - although it costs twice what an ACR does.
The Echo Charger manual is not only grossly misleading it is blatantly incorrect in many cases. I have been after Xantrex to make changes to that manual now for almost 10 years. They could really care less about the inaccuracies or misleading information and even today the manual remains unchanged..
FACT: The Echo Charger DOES NOT TURN OFF WHEN THE BATTERIES ARE FULL. It only turns off when house bank voltage drops below 13.0V. Pulling the fuse or dropping below 13.0V are the only things that turn off the Echo Charger.
More:
1) The manual is rather unclear that this device MUST be fed from the HOUSE bank and that ALL charge sources, solar, wind or alternator MUST be attached to the house bank. Competent installers know this but DIY's RARELY pick up on this. I have had approx 20 or more service calls for improperly wired Echo Chargers due to the piss poor manual. Because of this a $120.00 device quickly turns into a $300.00 device....
The Echo should not be used with a
factory wired 1/2/BOTH/OFF switch where the alternator feeds back through the starter cable. The Alternator needs to be re-routed to the house bank for the Echo Charger to work properly.
2) The Echo Charger does not work BACKWARDS and WILL NOT work in reverse like an ACR can/will. If your starting bank is wired to position #2 on the battery switch and the charge sources are feeding it first, because of the battery switch position, eg: factory wiring scenario, the Echo Charger will do NOTHING other than sit there and look pretty. This is not made clear in the manual..
3) I will quote the manual here:
Xantrex said:
When the input voltage is 13.0/25.5 volts DC or higher, echo-charge automatically switches ON. The LED glows a steady green.
So far so good but the input voltage for the Echo is always measured at the HOUSE bank therefore ALL charge sources need to be fed to the HOUSE bank first.This is not made clear in the manual and many of them get installed incorrectly then don't work.
Xantrex said:
When the input voltage is lower than 13.0/25.5 volts, the echo-charge automatically switches OFF, and the LED blinks green.
Again this is correct information. When the house bank voltage drops below 13.0 Volts the unit turns off.
Additionally the unit NEVER turns off otherwise! This too is not made clear and should be.. The Echo DOES NOT turn off when the start battery is full as many owners AND professional installers think it does. 13+ volts is
ON, less than 13 volts is
OFF. The state of charge of the start or reserve battery DOES NOT turn the device on or off UNLESS it is greater than a 10V difference and then the Echo shuts off or won't turn on at all. They NEED to make this clear that the Echo does NOT turn off when the start battery is "full"..
Back to the manual:
Xantrex said:
If the input voltage is above 14.4 volts (or 28.8), output will be limited to a maximum of 14.4/28.8 volts.
This is accurate and good because who wants to feed a fully charged battery at 14.5-14.8 volts despite the "low current".. The limit of 14.4 volts is a good one, unless of course you have a flooded battery that wants 14.6V to 14.8V to remain healthy such as Trojan.....
Xantrex said:
When it reaches 14.4/28.8 volts, the charge current will decrease, maintaining a float condition. The starter battery will be fully charged without overcharging.
Again this is grossly misleading and is pure BS. 14.4V is NOT a float voltage. All they are saying here is that the battery will accept less current when it is full than it does when less full. This is simple battery charging/acceptance 101.. The Echo does not, and will not, enter float mode independently from the house bank. As long as the house bank is in absorption or bulk the Echo is simply "following" its voltage up to a max of 14.4V.Nowhere on this planet is 14.4V a "float condition"...
So in summary:
1) The Echo DOES NOT shut off when the start battery is full.
2) Charge sources like wind, solar, alternator and charger need to be fed directly to the house bank. A wiring diagram and description including all charge sources is needed.
3) The Echo Charger is a one way device. It senses voltage from the house bank TO the starter bank. It will not work backwards like an ACR can.
4) It does not float the start battery independently of the house bank..
