I've been having an overheating problem with my Yanmar 3GM30F. I've had the boat for 12 years and know the mixing elbow has not been off and I wanted to eliminate that as a potential factor to the overheating. The overheating occurs after running at 3K rpm's for 30 minutes or so. I can run at 2500 for hours with no issue. I had prepared for battle with the exhaust hose and the mixing elbow but I had the hose off within 10 minutes and the elbow disconnected from the manifold within another 10.
I've attached pictures of the inside of the elbow after removal. This does not seem to be the source of the overheating as there is little build-up. I flushed water through the elbow and it did not appear to be restricted.
Would you agree that the elbow does not seem to be restricted?
