Stop swinging while at anchor
Mar 23, 2013
132
Hunter 44DS Lake Macquarie
Hi have you got any suggestions to help stop my boat swinging so much when at anchor currently sitting in 20 kn of wind swinging from side to side.
Sep 20, 2006
2,952
Best quick suggestion is to search on anchor riding sails or riding at anchor.
Drop and anchor from the stern, anchor riding sail, kellet on the rode etc.... lots of great ideas.
Don't worry. Be happy. Everybody does it.
Dec 2, 2003
1,637
If it is a short stay in tidal waters (but longer for lake sailors if no tide height variations) I just lower my kedge as a second anchor. I only pay out enough rode plus a bit so that it lays on the bottom. This acts as a drag, even though not actually set into the bottom. The effect is to stop the bow ranging around and it usually stops the movement - or at least dampens it so that it is not a problem.
Good luck.
Mar 6, 2012
357
Hunter H33 (limited edition cabin top) Bayou Chico
one of my best sailing buddies has a hunter 37.5 (shaman) and uses an anchor sail, even with our 27 cherubini tall rig tied up to his rail theres almost no swing.
Jun 26, 2004
150
Hunter 41DS Reed Point Marina
banner bay riding sail
works well for us on DS41,.. reduces swing by 70%
Apr 8, 2010
2,191
Little 'sail' with big results
We sourced an "anchor sail" from a local sailmaker/canvas shop many years ago. Works like the fletching on an arrow -- boat points right into the wind with only a few degrees movement either way. It only cost us $75. to $100. (I forget which)
(Our boat Used to sail back n forth a lot on the anchor before we added that sail.)
I will append a picture - it "sheets" tight to the end part of the boom. We bring a spinn. halyard around the mast to put upward tension on it.
Hope this helps.
Regards,
Loren
jsmac
Hunter 410 Severna Park, MD MD
Hi Loren, would you mind sharing the dimensions of your anchor sail? Yours looks much smaller than the bannerbaymarine one and is MUCH less expensive. Also what size is your boat and does anyone think sail size vs. boat size matters?
Thanks
Scott
Sep 20, 2006
155
Hunter 49 Mystic CT
My Hunter 49 with its high freeboard Lots of canvas and shoal draft keel swings like a crazy drunk. My boat neighbors always had these WTF faces. For a winter project I sewed up the riding sail from Sailrite and deployed that on the topping lift with traveler centered. The results were absolutely great. swing is down to 20 degrees side to side.
Apr 8, 2010
2,191
Thanks
Scott
IIRC, the sizing was close to the one from the Sailrite kit folks. Given that it sets way back towards the stern, it might take less area than one might intuit.
Our boat is 34' long and weighs about 11.5K in cruise mode.
Loren
Oct 18, 2008
45
Jeanneau 49DS Seattle
Anchor sails work great however they must be the correct size for the current wind speed. I choose to use a full chain anchor instead of rope/chain option. Still when the tides work against the wind I will deploy an additional anchor from the stern.
Aug 3, 2010
88
Oday 28 Malletts Bay, Lake Champlain
Are you using a bridle with twin ropes at the Bow forming a triangle before it goes into one?
Kestle
Jun 12, 2011
702
MacGregor 25 San Pedro
Can you explain this idea more? I haven't run a bridle. I just use a small stern anchor to drag slowly.
Jeff
Jul 27, 2011
5,144
Bavaria 38E Alamitos Bay
Best thing to do if it really bothers you is to trade for a heavy full-keel yawl or ketch, and hoist the mizzen a bit while at anchor. Shannon 38 (ketch) or Bermuda 40 (yawl) would be good choices!
jsmac
Bridge to Rode Attachment
Hi, can you explain how you attach/secure the anchor rode/chain to the bridle? That connection point is critical and since I use a chain I am not sure how best to attach it to the bridle. I am also assuming the bridle should be long enough to allow the chain and bridge attachment point to be at water level.
Thanks
