Yanmar 1GM10 Diesel Fuel Out Exhaust and only 2400 RPM
Jan 25, 2011
2,405
S2 11.0A Anacortes, WA
Before condemning the engine inards, consider doing a compression test, leakdown test and then another compression test with a "squirt of oil" into the cylinder and compare results.
Feb 7, 2016
29
J-Boat J22 Chandlers Landing
Adjusted valves. Gained 200 rpm. Still black water out. Lake water is a little brown, But not bad.
Feb 1, 2010
210
Hunter 33.5 El Dorado Lake, Kansas
Adjust them again! I did mine three times. It got better each time.
Feb 7, 2016
29
Pulled the head. What a mess. Replacing valves and valve springs. Should then be good to go.
Nov 22, 2011
1,193
Ericson 26-2 San Pedro, CA
Glad to hear that you are closing in on the problem. Please report back after you take care of the valves. BTW: I also have a 1 GM (not the 1GM10). It's been a good engine so far.
Jan 24, 2009
450
1981 Cherubini Hunter 27 Shipwright Harbor Marina, MD
I commiserate, my 1GM is also awaiting parts, so I've missed a couple of weekends of decent late season sailing. Good luck with it.
Feb 7, 2016
29
In conclusion, Turned out to be a crack in the head. Rings were good. Replaced (mechanic did it) head and miscellaneous parts including burned valve. Purrs like a kitten.... for a 1 cylinder.
Jan 24, 2009
450
Congrats! Hopefully I'll be up and running in a week or two, will be good to get back out on the water.
