I just removed all of my foam to clean the bilges and scrape off some failing paint. Glad I came across this post. I was/am so tempted to toss it just because most of it is so old and nasty. how does the spray foam method work? (Chief) are you just cutting loose with it in the bilge or what? I have to admit I am still on the fence about just getting rid of some of it. ALL THAT SPACE! oh btw I'm really not into tight spaces so I guess thats why Im still considering it.
The blue foam at the home improvement stores, I have gotten some of that before for building RC plans. If you keep an eye out you can find it damaged some times for dirt cheap!! I got a whole fan folded bundle for $5!! It was basically just dusty.
I took all of those blocks like you have, washed them with soap and water and dried them in the sun. I then cut them all down into lots and lots of approximately 2" square cubes.
One of the quarters in our old Venture (port side) is factory decked over all the way from the cabin to the laz. I packed as many cubes as I could (force rammed) under that quarter. I decked the starboard quarter over and did the same. Now both quarters are decked flat all the way back and under the cockpit is cleared of foam blocks. Much of the foam that was under the the Vberth also went under the quarters cubed and I brought home much more even and got it in there.
I put a simple divider (now a glassed in bulkhead) in the far front under the Vberth deck and stuffed it full of cubes. I got a hold of 12x12x2" styrofoam and this fits nicely along the hull sides under the remaining vberth - unlike the huge blocks.
I cut open the empty space under the portapotty mounting and jammed a butt load of additional foam in there and closed it up with an inspection plate.
Now I plan to buy sheets of foam board and glue it up to places such as the underside of the vberth deck and perhaps in some places in the combing.
I have no plans to use these spaces for readily accessible gear and I was going to do all of this decking and such anyway so why not stuff with foam? I added quite a bit, can easily add more, its a light light boat and if having foam buys us even 10 minutes when it counts - why not?
