Removing Black Marks and Scuffs
Hello all,Just getting back in tonight from the cabin. What a weird, yet wonderful day in central Wisconsin. Cloudy, overcast and humid all day with very few periods of very light rain. Turned into a tremendous cloudless evening, with perfect sailing breezes. My only problem is that I have not put the boat on the lift yet. I have been getting everythng else ready for summer, yet have not put the Hunter into the drink.Interesting enough, I did spend the entire day last Sunday polishing the hull, inside and out.The boat was filthy. I have not gave it this thorough a going over since I bought it. I had all kinds of black marks on the hull from shoes, shrouds, bike tires and the big one from hitting the pier one day last summer when I got hit by a hard gust just as I was coming up to the pier. I have bumpers along the edges of the pier thank goodness but that one not only marked up the hull but did scratch it also. OUCH...After washing the boat with soap and water on Saturday, I spent all day last Sunday, and I mean 6 hours, polishing by hand and the boat looks brand new. You can still see a few scrathes, but you have to look for them. It shines and ALL the marks are gone!!!I really do not think that the product is what is important to remove the marks, but what is important is that you work them out. I still use Starbrite Premium Marine Polish with Teflon, simply because it is readily available locally. Again, a good marine wax is great, Maguire's (sp), as recommended, is excellent. I used a standard yellow polish cloth as well as cotton towels I picked up in the auto section on WalMart. Nothing special. I would squirt a quarter to half dollar sized circle of the polish onto the rag and scrub the heck out of a small area say 12" x 24" or so. Wipe back and forth, cirular, up/down...whatever, but put some force into it. I did not let the product dry to a haze as they all recommend, but scrubbed until it was all gone. I covered every inch of the boat, inside and out. I guess that you would say I scrubbed it with the compound versus simply rubbing it on. On the real stubborn stuff, my pier scratch, the area that the shrouds have been rubbing against as it trailers as well as the marks that the tie downs leave from trailering, I did the same thing but scrubbed those areas down with 3M Synthetic Steel Wool and the polish. This was supposed to be an equivelent to 0000 Steel Wool. Worked very well. I do not know if I would actually use the real steel wool, but this stuff really worked.When I was done, I was sore and tired. We used the same stuff on the Sea Doos and man it works to get all the water spots off the fiberglass hull.Wax and polishes are mild abrasives and will do the job very well if you put some muscle behind the product. Simply following the directions to swirl on, let dry to a haze and rub off will not give you the results that you want to clean the hull. Once it is clean, follow those directions to put a second coat on to allow for a beautful cover and shine.Hope this works for you. In the future, leave a bottle of your wax or polish near your boat and rub out the marks at the end of the day. I say that but I sure don't follow that either!!!Godspeed,Rusty
