@Ralph Johnstone I think Rich is talking about his "tape" over the joint as the wrapped temp fix, not the teflon tape/sealant applied directly to the ferrule.
With the teflon/tape and Permatex #2 how do you tighten the nut? (your post 46) The standard/recommended procedure to tighten a ferrule fitting is to do it by "turns" rather than torque. In other words, for a certain size of tubing with a ferrule fitting, you tighten the nut a certain number of turns (say 1 1/4 turns)and use a "go/no-go tool to confirm. Overtightening is often the cause of a leak for this type of a fitting. I would seem using the tape may change the number of turns? Just asking. From
Distance vs. Torque
Typically the procedure for tightening a compression fitting is specified using the rotation of the nut as the key metric, rather than torque. Compression nuts are threaded, meaning that the number of rotations of the nut is directly correlated to the linear compression of the ferrule, based on the thread’s pitch. Torque, on the other hand, can vary greatly, depending on fitting and ferrule material, lubrication, degree of galling (for stainless fittings), and other factors.
Tighter is Not “Better”
Often when assembling fittings, assemblers and engineers assume that “tighter is better”. This does not hold true for compression fittings. As described in the “Ferrules” section above, the optimal seal is created by a line contact between the ferrule and the tubing. Insufficient tightening of the compression nut will not deform the ferrule enough to create this contact, but over-tightening will deform the ferrule too much, creating a surface contact. A surface contact weakens the seal and often results in leaks
