Hi, I am new owner of 1979 Catalina 25 swing keel without a trailer. I bought it in search of a shoal draft boat because the dock only has shallow depth slips of less than 3' at low tide and no more than 4' high. It has a just got a bottom job and it is in boatyard and it seems timely to also do maintenance and redo the swing keel parts. The question is how far to go. Catalina Direct says to replace keel cable at least every 2 years. Also recommend a "Keel Hanger Casting kit" with new pins, bolts, ball, etc. , plus "Keel centering Spacer" kit to stop swing of keel and therefore wear of pin, hull clunk, etc.
They also say don't moor boat in slip with keel up. So then what's the point as most owners I know have keel up at dock???
Doubt prior owner did any maintenance given bottom condition.
Have any of you installed the retrofit kits?
Are all those what I should do? Your advice welcome. Thanks, Frank
