Shroud anchor point
May 23, 2023
28
Catalina C-22 Yard
I recently received a 1976 Cat-22 so have no experience with it. I am in the process of refurbishing it and have a question about what I think is a weird shroud anchor. Please see attached photo. This is a standard U-bolt that the center shroud is attached to. This is the one that goes through the spreader in the mast. This U-bolt is behind the aft shroud anchor and simply goes through the deck with no water proofing. This appears to me to be out of place. Fortunately, I feel no sponginess in the deck in this area.
Should I remove and patch the U-bolt? There is one in the same location on the other side. Have any idea why this might be here?
Thanks,
Mike
29
Catalina 22 Davis Island Yacht Club
The short answer is it's wrong. The upper shroud should anchor to the middle chain plate shown in your picture. Does the boat have lower shrouds? There should be a forward and aft lower shroud. Would be very curious to see a picture of the full view of the shrouds.
Likes: JBP-PA
May 23, 2023
28
Catalina C-22 Yard
Thanks, I thought that looked wrong. This boat does have the forward and aft shrouds. If you look at the photo, you can barely make out the anchors for all three. I am assuming that is what you are calling the chain plates? Still learning terminology. I will remove these U-bolts this week. I am planning on filling the holes with epoxy. Is this a correct solution?
Likes: JBP-PA
JBP-PA
Apr 29, 2022
411
Jeanneau Tonic 23 Erie, PA
You are absolutely right. The bolts you circled are where your shrouds should attach. Who knows what that u-bolt was intended for. Fill the holes with thickened epoxy. Epoxy needs UV protection, some paint will do.
JBP-PA
Apr 29, 2022
411
Yea, they are still called chainplates even though they are bolts not plates (on your boat) and there are no chains.
Sep 30, 2013
3,547
Could there be some extensive core rot in the vicinity of the original chainplate? I can think of no other reason someone would have done such a sinful thing with that U bolt.
May 23, 2023
28
Catalina C-22 Yard
My thoughts as well. When I checked, there was no rot. Glad I removed them today. When I unbolted the port side, it broke off it was so rusted.
Thanks everyone for your help. I am sure I will have more questions to come.
Likes: Gene Neill
Oct 13, 2020
135
catalina C-22 4980 channel islands CA
You are headed in the right direction, you may want to consider replacing you original chain plates with new replacements from Catalina Direct. They are nice and have large backing plates and a top plate with screws to keep them from spinning. When I replaced my original ones one of the snapped off too. There is a great youtube video on how to line them up so you wont bend your turn buckles when raising the mast. They basically line up with with center of the chain plate pointing at the mast. Best of luck, Dano
Sep 23, 2021
29
I wondered if they created a swept back shroud and eliminated the lowers.
Sep 23, 2021
29
Yeah. I didn't mean to imply it was a good idea. I just can't understand why they did it.
Sep 24, 2018
2,652
O'Day 25 Chicago
There's rot under the fiberglass deck. You won't see/feel it unless you make a bigger hole but one look at that rust tells me it's near impossible for the core not to be rotted
May 23, 2023
28
Catalina C-22 Yard
You are most likely correct. I temporarily plugged the holes with butyl tape. When I go to epoxy, I will enlarge and inspect.
Sep 24, 2018
2,652
O'Day 25 Chicago
I've seen a few other boats that use U bolts instead of a flat piece of stainless. Perhaps the U-bolt helps with stepping the mast or simply the fact that it was available at the hardware store. I sincerely hope it's fastened to a bulkhead somehow. I doubt the rotted deck will hold up
Jul 13, 2015
902
Catalina 22 #2552 2252 Kennewick, WA
and while you're at it-- go chase that Ubolt into the cabin? Not a whole lot of meat up there-- and with such an odd approach to what is now forward of the forward lowers; I'm really hoping your main stays are attached to the bulkhead via the chainplate? Aft and forward are deck through mounted with a backing plate: (and this is pre upgrade with the stock '73 hardware which has since been replaced and upgraded to larger stock): view is port looking back from the v-berth; F/forward M/Midships A/ Aft
