Sorry, NOT Renogy, but Eco-Worthy...
Guess I looked at too many panels and became confused over Mfg...
Call them with your serial numbers. Supposedly it is only panels sold from April through October of 2015.Any idea how you know if you are in the recall panels window? Or is it ALL panels, or ?? I bought 2 in Sept of 2014. Used them for a short time with no problem. They are on the boat, but only out when needed and not hard mounted.
Greg
Here are the serial numbers of the suspect panels I received from Renogy:This is my first attempt at solar. I purchased a 25 W panel from Renogy and am a little disappointed in what I perceive as 'quality'.
Several of the lines appear to not be same diameter and there appears to be some issues around the perimeter of the mounting board(worse on one end than other perimeters).
Should I worry about these things (remember, first experience with solar panels). Just purchased/received, not installed. If a problem, would like to get it corrected before any other expense incurred.
