I recently purchased a used H170 and was thinking about getting a motor for it. Is a 2 or 2.5 HP about the correct size? Do I need a long or short shaft?
Thanks
Thanks
I would STRONGLY recommend you stay with lighter motors. The motor mount is fastened to a plywood square embedded within foam that forms the cap. Excessive weight or thrust can damage the area. The mount can be modified to bond to the hull but without additional support you're bound to rip the mount off of the deck.Thanks BlueRunner. I have the option of purchasing a newer Mercury 4 HP with the F-N-R which might be nice. I am concerned about the weight -55 Lbs - and the outpur of 2.9KW. Not sure if this might be too much for the Hunter motor mount.
Your thoughts?
You can use other plastic mix epoxy products then sand and paint them. I found that Krylon white gloss was a very close color match to the ACP Hunter 170 I owned.That is exactly the information I was looking for. Also I am in the process of repairing some minor cracks in the cabin area. I found the proper plastic welder epoxy in white from McMaster Carr Supply that works great.
